Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Like Tree1Likes
Thread: Revit 2015 : Bugs n' Such
  1. #11
    Senior Member Charles Karl's Avatar
    December 6, 2011
    Fairbanks, Alaska
    987
    01:04 PM
    DS, you need to tone down your Jitter.
    At first I thought you were referring to WTF as jitter,..LOL. Not familiar with 15 yet.
  2. #12
    Austin, Texas
    287
    04:04 PM
    Not at my machine now but I tried the new disallow join on bar joists and attempted to move the connection and it crashed both times. Bug?
  3. #13
    April 4, 2013
    92
    04:04 PM
    Quote Originally Posted by Alex Cunningham View Post
    Does it print the way you have shown?
    Yes, it prints out, exports as jpgs, and print to pdf exactly how it shows on screen.
    Anti Aliasing definitely made the lines more crisp but did not help the surface patterns. I can replicate this problem with a new out of the box template, maybe this is a designed feature? Can anyone else test it out?
    Edit 2: I don't even know what to think anymore. Like someone said earlier, It bends the surface pattern into the geometry, and the amount of jitter does not have anything to do with whether it happens or not.
  4. #14
    October 19, 2011
    1
    09:04 PM
    Glad it's not just me, Autodesk's help center says:
    1. Turn off surface patterns for the affected elements: right-click an element and click Override Graphics in Viewby Element or by Category. Expand Surface Patterns, and clear the Visible check box.
    2. Reduce the value of the Jitter setting on the Graphic Display Options dialog. (this doesn't work)
    So it looks like the best solution is to just turn off the pattern, what a waste. Hopefully there is a fix coming.
  5. #15
    Member kowen1208's Avatar
    January 18, 2013
    Utah
    354
    03:04 PM
    I don't think the jittery lines extending into the geometry would be a problem if the lines jittered randomly. However, with siding and similar patterns, the jitter lines look like they're just copied and pasted down the whole wall. The point of jittery lines is to make it look hand drawn, but if each jittery line is identical to the one next to it, it defeats the purpose.
  6. #16
    Gold Coast
    2,631
    07:04 AM
    Quote Originally Posted by kowen1208 View Post
    Revit doesn't know how to do random, everything is calculated. Might take a few releases to get this feature more to peoples liking. Personally, I won't use it when Photoshop can do things so much better.
  7. #17
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,186
    05:04 PM
    Quote Originally Posted by Dsmelcer View Post
    exact same result here, using the OOTB Architectural Template & a 6" parallel line model pattern.
  8. #18
    Member Mike Ferrell's Avatar
    London, Ontario, Canada
    60
    05:04 PM
    Filled Topo Cut pattern
    Opened a project in 2015 and first thing I notice is that 2015 is filling the existing topo with the soild fill override we use for the existing phase. Revits never done that before.
    Revit 2015 : Bugs n' Such-2015.jpgRevit 2015 : Bugs n' Such-2014.jpg
  1. bugs I tells ya, bugs!
    By elton williams in forum Architecture and General Revit Questions
    Last Post: August 31st, 2016, 10:41 PM
  2. Replies: 0
    Last Post: March 28th, 2014, 12:15 AM
  3. Replies: 0
    Last Post: March 25th, 2014, 01:45 AM
  4. Not one but TWO cryptic Revit 2014 text bugs can anyone confirm them?
    By basilmir in forum Architecture and General Revit Questions
    Last Post: February 17th, 2014, 04:50 PM
  5. Revit 2014 bugs - vote on their severity
    By Wes Macaulay in forum Architecture and General Revit Questions
    Last Post: June 16th, 2013, 07:36 PM
