Results 1 to 3 of 3
Thread: Room finish schedule.
    Member Alfienoakes's Avatar
    January 4, 2011
    West Sussex
    218
    06:54 AM
    I know, I know.. many questions on this, so this isnt about HOW to create one..
    I am attaching some parameters to my rooms for walls, as we have floor finish GA's and reflected ceiling GA's that pick up those finishes. What I want to do, is attach parameters to my "Rooms" and on some of these, have them as material parameters. I can then go to the materials editor, and choose the one I want. ie:
    Parameter = "Wall - North"
    as a material, which I can then pick the correct Paint finish for that wall. I know its not true BIM etc, but it at least means I can pick from a list of correct materials, rather than letting someone type in "Paint - emulsion" each time and spell it wrong etc..
    Will this cause Revit to have a fit somewhere else down the line, by attaching multiple material parameters to my rooms.? I cant think that it might, as these are only parameter entries, rather than an object that has taken on the actual material.?
    Cheers
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,301
    11:54 PM
    How are you planing to use the material information in tagging?
    January 4, 2011
    West Sussex
    218
    06:54 AM
    Hi Jim,
    Thats a good question.. Now I have looked at it, I think the only benefit it gives me, is that I can pick a material from the material library. I thought I may be able to mix the material keynote into my "room schedule" finishes sheet.. but I cant.
    So, I might just switch back to using key names, as its a very standard project, and I really just want it for surface colours, ie "Painted MDF - White"..
  1. Door Schedule - To Room From Room
    Last Post: June 7th, 2017, 12:55 PM
  2. Revit Room finish parameters
    By ainebim in forum Architecture and General Revit Questions
    Last Post: May 30th, 2013, 01:24 PM
  3. Floor Finish Material to Room Tag
    By archizen in forum Architecture and General Revit Questions
    Last Post: May 28th, 2013, 01:14 PM
  4. Floor Finish Schedule
    By Ashraf2005 in forum Architecture and General Revit Questions
    Last Post: October 12th, 2011, 01:36 PM
