Results 1 to 2 of 2
Thread: help with Curtain Panel with Triangular Filleted Hole
    April 4, 2012
    4
    10:41 PM
    Unhappy help with Curtain Panel with Triangular Filleted Hole
    Hi everyone, I've made a curtain panel (pattern-based) family with the Triangle Bent template. It works perfectly in the family environment, but some panels can't be created in a project environment.
    family:
    parameters :
    project :
    As you can see, only every other panel is created, despite the void in the family going in both directions. The missing panels throw an error and the only option is to click ok & delete them...
    Any suggestions ?
    Attached Thumbnails Attached Thumbnails help with Curtain Panel with Triangular Filleted Hole-2yljpdt.jpg   help with Curtain Panel with Triangular Filleted Hole-2d2sue.jpg   help with Curtain Panel with Triangular Filleted Hole-9fzbt2.jpg
    Attached Files Attached Files
    April 4, 2012
    4
    10:41 PM
    Ok, so if I take out the void & associated linework, the family works. Anyone have ideas why the void might be causing these problems ?
  1. Sticky Notes: Curtain Wall Basics - Empty Curtain Panel
    By Sticky Notes in forum Blog Feeds
    Last Post: June 14th, 2012, 02:45 PM
  2. Curtain Panel Mullions
    By Drew in forum Architecture - Family Creation
    Last Post: February 3rd, 2012, 05:11 PM
  3. Filleted Triangular Panel - why so complicated?
    By funkys in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 30th, 2012, 03:17 PM
  4. Curtain Panel Layout
    By hypnox1 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 7th, 2011, 07:42 PM
Tags for this Thread
