Donate Now Goal amount for this year: 3000 USD, Received: 2475 USD (83%)
Results 1 to 7 of 7
Thread: Revit 2013: Service Pack 3 - install issue
    Moderator LeanneZ's Avatar
    December 8, 2010
    Charlotte, NC
    738
    11:49 AM
    Just installed 2013 Revit Design Suite Premium (Revit only) and running under Trial Version on my home Windows 8 machine.
    I've downloaded the Service Pack 3 for my installed version and began to install the update. The update seemed to hang; the install was taking over 30 minutes to install and the progress bar seemed to stay at about 70%. I ended the task.
    When trying to re-install the update, I received the following error:
    "A problem prevented the Update Release from being installed. Contact your system administrator.
    Error Code: 1618"
    What can I do to clear this up and get the update installed?
    Coeur d Alene, ID
    4,256
    08:49 AM
    I had some issues with the "trial"....it never seemed to work correctly. When I installed a version from the USB and updates it worked just fine.....I'd uninstall everything and redownload....
    February 2, 2011
    Montreal/Paris
    802
    10:49 AM
    Did you disable the anti-virus?
    December 8, 2010
    Charlotte, NC
    738
    11:49 AM
    Not what I wanted to hear.
    I got the Revit installation from a USB. It's an hour drive to get my hands on it again (with another hour drive home.) Downloading from the internet seems to be a lengthy and often error-filled exercise at my house. Blah.
    I was hoping there were just some files from the interrupted Service Pack install that I could delete and start over.
    December 8, 2010
    Charlotte, NC
    738
    11:49 AM
    THIS:
    Quote Originally Posted by DanielHurtubise View Post
    (no, I hadn't. But I tried again tonight with AV off.)
    and the link in This Post: http://www.revitforum.org/architectu...tml#post105046
    BAM! Updates were Successful!
    Thanks Y'all!
    Coeur d Alene, ID
    4,256
    08:49 AM
    Quote Originally Posted by LeanneZ View Post
    THIS: (no, I hadn't. But I tried again tonight with AV off.)
    Thanks Y'all!
    Sigh....besides that did you remember "Run as Administrator"....
    Glad you got it worked out...!
    Wait....that was my link...
    December 8, 2010
    Charlotte, NC
    738
    11:49 AM
    I did not do anything specific to "Run As Administrator." But since it's my personal laptop, and I'm the only user, I'm assuming everything I run on it is "As Administrator."
    Yup. That was your post. I was able to find the correct SP3 install Monday night, however, each time I tried to download fresh and install, I was running into issues. Using Daniel's advice to turn off AV and just choosing your link (so I didn't have to find it, again, myself) it all finally worked out!
    Leanne = Happy Camper!!!
  1. Replies: 0
    Last Post: October 16th, 2012, 02:15 PM
  2. Revit OpEd: Revit 2013 Service Pack 1 Available
    Last Post: July 21st, 2012, 06:48 AM
  3. Windows 7 Service Pack 1 and Revit
    By Wiley in forum Architecture and General Revit Questions
    Last Post: August 11th, 2011, 02:50 PM
  4. REvit 2012 Service Pack 1 out?
    By DaveP in forum Architecture and General Revit Questions
    Last Post: July 11th, 2011, 03:35 AM
  5. Revit 2012 Service Pack / Web Update 1 out soon
    By Munkholm in forum Architecture and General Revit Questions
    Last Post: June 10th, 2011, 10:21 AM
