Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Like Tree5Likes
Thread: Door Schedule - To Room From Room
  1. #11
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    319
    06:33 PM
    A little hack-ish, but you could create a large Room around the building with Room Seperation Lines, and call/number that Room exterior?
    I would just leave the value blank.
  2. #12
    Junior Member jstewartarch's Avatar
    August 21, 2012
    Atlanta GA
    8
    12:33 PM
    Thanks,
    I wish I could leave it blank, but unfortunately our client likes to see it. Ah the things we have to do . . .
    I have set up a parameter that uses the "to" and "from" room names when it is left blank I can add a 1 in my Exterior parameter and it will place Exterior in the box. Just one of those things you have to workaround.
    if(EXTERIOR = 1, "EXTERIOR", To Room: Name)
  3. #13
    July 18, 2013
    12
    02:33 PM
    I have been looking for this answer for a long time! Thank you so much!
    Is it possible to have the parameter "Room" show in my door tag?
    Quote Originally Posted by David Conant View Post
    Until the Revit team makes the room calculation point modifiable on an instance basis, you won't have a perfect solution. With a little work on your own you can get close.
    Create a shared Yes/No parameter "Outswing"
    Add "Outswing" to your door families as an instance parameter and load into your project
    In your door schedule, add To Room:Number and From Room:Number fields
    In the schedule, create a calculated parameter "Room" with the formula if(Outswing, From Room: Number, To Room: Number)
    In schedule properties Formatting tab, hide To Room:Number, From Room:Number, and Outswing if you don't want to display them.
    Select any door you want to show with the from room number and check the Outswing property.
    In the schedule, you have one column Room to show either the To Room or From Room number.
    The image shows a snippet of schedule without hiding the columns so you can see all the values. Obviously,the Room column can be located wherever you need it. Parameter names can be changed to whatever works best for you.
  1. Door not displaying Room information in schedule
    By krushert in forum Architecture and General Revit Questions
    Last Post: July 11th, 2018, 09:47 PM
  2. Door From/To Room Value in Schedule
    By pfaudler in forum Third party Add-Ins, API and R&D
    Last Post: December 10th, 2016, 09:37 PM
  3. Door properties "From Room: Number" does not change when door flipped
    By hclbaumbach in forum Architecture and General Revit Questions
    Last Post: September 19th, 2012, 07:48 PM
  4. Door not displaying Room information in schedule
    By brett05 in forum Architecture and General Revit Questions
    Last Post: July 31st, 2012, 10:00 AM
  5. Door tags and Room numbers
    By ncebula in forum Architecture - Family Creation
    Last Post: May 17th, 2012, 09:28 PM
