Results 1 to 9 of 9
Like Tree7Likes
  • 3 Post By DanielHurtubise
  • 1 Post By Cyus
  • 2 Post By MPwuzhere
  • 1 Post By Gabriel Black
Thread: Coupe on rooftop.
    Member Gabriel Black's Avatar
    April 6, 2011
    Belgium
    203
    05:59 AM
    Coupe on rooftop.
    I have no idea what this would be called in english, but in Belgium it's called a coupe.
    Being an MEP user, I'm not sure how I would make this in revit.
    Would it be an item that I'd model as an in place family (as a once off in the project) or make a re-usable family? If I'm to make a re-usable family, which template do I begin with?
    A little perplexed how to begin with this one.
    It's a structure of steel beams and glass mostly.
    Attached Thumbnails Attached Thumbnails Coupe on rooftop.-img_1014.jpg   Coupe on rooftop.-img_1020.jpg
    Coeur d Alene, ID
    4,814
    07:59 PM
    Create a pyramid mass then apply a curtain system to the faces...adjust the curtain grids and mullion sizes as needed....no family needed...
    February 2, 2011
    Montreal/Paris
    830
    09:59 PM
    Way too much work.
    It's a simple sloped roof made out of slope glazing.
    JeffH, MPwuzhere and Gabriel Black like this.
    Member Cyus's Avatar
    July 10, 2012
    London / MK
    490
    03:59 AM
    I don't know what it's called in english either but coupe sounds cooler than a pyramid rooflight.
    I'd just make it as a sloped roof as suggested above - I'd think that's easier than a family. Depends if you need to model the steel beams as structural beams, or you can use the mullions as beams instead.
    Gabriel Black likes this.
    Coeur d Alene, ID
    4,814
    07:59 PM
    Quote Originally Posted by DanielHurtubise View Post
    Way too much work.
    Yeah....just tried to figure out how to create a pyramid mass for the past 15 minutes...gave up, have to get ready for work.
    Gabriel Black and cellophane like this.
    April 6, 2011
    Belgium
    203
    05:59 AM
    I'm about to leave work...to continue working at home.
    The item doesn't need to have any structural info. The mullions / beams simply need to be in the correct place to ensure no clashes.
    Thanks guys! I may have this thing beat now!
    Senior Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    788
    09:59 PM
    Quote Originally Posted by Gabriel Black View Post
    I believe this special type of glazed cupola is called a Roof Lantern.
    Here is a revit family from manufacturer:
    LINEL BIM Objects
    April 6, 2011
    Belgium
    203
    05:59 AM
    The glazed roof trick did it! I could also duplicate and customize the mullions and beams as required and move them into postion (as built) no problem!
    The building looks far better than I ever expected and most importantly the people who need impressing (my boss) is impressed.
    Thanks for all the advice and help guys!
    Cyus likes this.
    Austin, Texas
    287
    09:59 PM
    It's extremely un-intuitive but you can make it by sweeping a triangle centered in a square. The square is the path
  1. Comment masqué les lignes qui coupe les objet 3D
    By Banditfx7 in forum Forum Français
    Last Post: March 22nd, 2013, 08:54 AM
  2. Toiture pan coupé avec revit
    By nico5715 in forum Forum Français
    Last Post: July 28th, 2012, 07:00 AM
  3. Un paramètre partagé dans une étiquette de coupe (si,si...)
    By jbenoit44 in forum Tutoriels, trucs et astuces en français
    Last Post: April 3rd, 2012, 09:45 PM
  4. Prefa : longueur et longueur de coupe
    By Jeff_64 in forum Forum Français
    Last Post: January 22nd, 2011, 12:53 PM
