Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By cerb0z
Thread: random screening wall
    December 19, 2013
    1
    02:10 AM
    hello,
    do you guys know how to make random screening wall in revit?
    or- any suggestion how to do it?
    thanks!
    Member cerb0z's Avatar
    July 5, 2011
    Belarus, Minsk
    244
    10:10 PM
    d.stairmand likes this.
    April 12, 2015
    Bangalore, India
    2
    12:40 AM
    Easy, i tried it with a concrete / masonry wall. use the wall tool, then go to edit profile. revit will ask you to choose the appropriate view (mostly the elevation) to sketch the profile of voids . In the elevation view, draw the shape of void as per the design intent. Here is a tip, as a proficient autocad user, i find it easy to do all the sketching in autocad and import/ link this cad inside the sketch mode of the wall elevation and used the acad vector lines as the sketch lines. As could be seen from your image, the screen wall profile is quite complicated and it will be cumbersome to sketch it in revit.
    As a rule, i use autocad as much as possible. It is way better than revit when it comes to sketching 2d lines. The attached image is what i did in cad, not as complicated as your model, but it definitely saved me a lot of time working in cad.random screening wall-3d-view-10.jpg
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    343
    07:10 AM
    Not to put a dampener on a good tip, but what you are saying is:
    Start Autocad Up, Draw a series of random Rectangles, Save the File, Start Up Revit, Link in the CAD File, Edit Profile a Wall & then trace the Rectangles.
    Why not just: Edit Profile a Wall & then draw random Rectangles?
    Member byk3bep's Avatar
    January 30, 2014
    449
    08:10 PM
    Make a panel using the generic model adaptive, host it to a divided surface and array it. The panel should have a yes/no visibility parameter controlled by dynamo.
    However, this might be out there...
    ps Never, ever use cad to trace over in revit.
    Spend a couple minutes reading on that subject before you decide to go down that road...
    April 12, 2015
    Bangalore, India
    2
    12:40 AM
    Smile
    ".....Why not just: Edit Profile a Wall & then draw random Rectangles?
    well for a proficient cad user like me, it is convenient using cad. It is the most user friendly tool when drawing 2D lines. Maybe the example quoted does not substantiate my claim, but if you had a wall full of complex voids, a "bird's nest" for example, i seriously recommend CAD. But then, to each his own. I only mentioned what is suitable for me
    10,127
    02:10 PM
    Don't take offense, but it's *suitable for you* probably because you don't know revit that well. The interoperability between revit and cad is terrible, and it causes all kinds of stability and performance issues. Linking in CAD at all is bad but necessary. Tracing it with revit lines- however- can mangle a project very quickly.
  1. Elevation with Random Distribution Panels
    By Ashraf2005 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: September 17th, 2013, 04:33 AM
  2. Random GUI element when opening or synching
    By Steven Thedens in forum Architecture and General Revit Questions
    Last Post: May 23rd, 2013, 01:19 PM
  3. Seemingly random Wall Join Behavior?
    By SuperDave in forum Architecture and General Revit Questions
    Last Post: April 3rd, 2013, 06:24 PM
  4. Random Remote connection Question
    By cwetzel in forum Out There
    Last Post: June 15th, 2012, 02:22 PM
  5. Random Window & door Heights
    By mark b in forum Architecture and General Revit Questions
    Last Post: December 11th, 2010, 08:10 PM
