Results 1 to 4 of 4
Thread: Combine 2 filled regions
    October 11, 2013
    42
    06:21 AM
    Is there any way to combine 2 filled regions to be 2 parts of the same object rather than 2 separate entities entirely?
    I know I could redraw them into the same one but the reason behind it is a far larger scale and I’m sure there must be an easier way. In 3dmax which was my poison for the last 4 years id have simply selected the individual splines and attached them to one another to create one object.
    Coeur d Alene, ID
    4,817
    10:21 PM
    You can combine PAT files...I do this for ceiling tiles and floor patterns... Problem is they are all the same weight. If you want one to be darker than another you will have to use a combination of some sorts...
    JBZ
    JBZ is offline
    Senior Member JBZ's Avatar
    December 17, 2010
    Los Angeles
    670
    10:21 PM
    Haven't played with it in a while but HatchKit may be worth looking into for this, they have updated it AFAIK for 2014 & Revitina ;-)
    October 11, 2013
    42
    06:21 AM
    Thanks guys i'll look into both solutions and see what I can find!
  1. Filled Regions not playing nice.
    By Alex Cunningham in forum Architecture - Family Creation
    Last Post: November 8th, 2016, 08:02 PM
  2. Cannot tag over filled regions?
    By Andres Franco in forum Architecture and General Revit Questions
    Last Post: October 15th, 2013, 08:11 PM
  3. Background color for filled regions
    By Pashcal in forum Architecture and General Revit Questions
    Last Post: June 15th, 2012, 08:32 AM
  4. Parametric Filled Regions???
    Last Post: April 21st, 2012, 05:50 AM
  5. Filled Regions and Floors
    By retroface in forum Architecture and General Revit Questions
    Last Post: June 17th, 2011, 01:49 PM
