Results 1 to 3 of 3
Thread: 0 daylight portal
    November 10, 2013
    1
    01:59 AM
    Question 0 daylight portal
    Hi
    I am designing a restaurant - interior and exterior- and I need to render both side. I did some draft rendering before and daylight portal was normal in interior and exterior. I am really in hurry for doing exterior render but day light portal number is 0.I checked sun setting,section box and make the section box as big as possible to surround the sun! but i don't have day light portal . I applied image for background scene, my render light get normal, but day light portal number is 0 yet!!! if you know somethings about daylight portal , I would be grateful if you share your experience with me. i don't know what should I do!!
    December 21, 2010
    Phoenix, AZ
    2,576
    01:59 AM
    Daylight portals are only used if you have the Lighting set to Artificial... and I think Interior.
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    03:59 AM
    Portals are available for all settings (I think). You turn them on for windows, doors, and curtain walls through the Quality Settings (scroll down to Edit, then the check boxes are at the bottom).
    I don't know why you'd want light portals for an exterior rendering, though. You shouldn't need them. Just set up your sun properties and turn on your shadows.
    Oh, and welcome to RFo.
  1. David Light: Daylight Visualiser
    By David Light Blog in forum Blog Feeds
    Last Post: December 30th, 2012, 10:16 AM
  2. What Revit Wants: Polantis - another BIM Content Portal
    By luke.johnson in forum Blog Feeds
    Last Post: March 7th, 2012, 04:15 AM
  3. steel portal frame
    By revit-new in forum Structure - General Questions
    Last Post: October 7th, 2011, 06:15 AM
  4. Daylight portals
    By bayswater in forum Architecture and General Revit Questions
    Last Post: August 25th, 2011, 12:48 PM
  5. Daylight Savings Time
    By JTB in forum Architecture and General Revit Questions
    Last Post: May 30th, 2011, 11:46 PM
Tags for this Thread
