I'm having an issue getting my curtain wall panel to display properly when I insert it into a curved wall.
From the picture you can see that in the regular curtain wall to the right it is oriented the correct way, but when I add it to the curved wall on the left it turns 90 degrees for some reason.
Problem with adding custom curtain wall panels to curved curtain wall.-untitled.png
Any help on this would be very appreciated.
