Results 1 to 6 of 6
Thread: Dimension - Angular
    Member Joshua Kohl's Avatar
    From Utica, NY currently in Allentown, PA
    162
    03:46 AM
    Question Dimension - Angular
    When I click on an angular dimension, I want to be able to "modify witness lines" to add other angles to the string.
    However I don't get that option like I do when I click on a linear dimension.
    Is this by design?
    Will i need to delete the whole string of angluar dimensions I already have and create it again from scratch just to add one to the end?
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    02:46 AM
    You can't do an angular string. They are all just separate dimensions. So, just add the other ones.
    162
    03:46 AM
    Quote Originally Posted by dzatto View Post
    I have a string of them here though...I have radial lines from the center point of a radius with a single string of angular dimensions between them.
    dzatto's Avatar
    December 9, 2010
    5,234
    02:46 AM
    I just tried (before I posted) and it wouldn't let me do it! Now I'm confused...
    Actually, you need a string to do an equality. hmmmm what the heck is going on?
    Are you on 2014?
    EDIT:
    Oh nevermind. I was doing it wrong I guess. I got it to work as a string. I don't think you can edit the witness lines, though. But, hey, I couldn't even get a string to work earlier, so I wouldn't trust what I'm saying.
    162
    03:46 AM
    Are you on 2014?
    Yes 2014
    JBZ
    JBZ is offline
    Senior Member JBZ's Avatar
    December 17, 2010
    Los Angeles
    670
    12:46 AM
    Quote Originally Posted by Joshua Kohl View Post
    Yes one CAN (obviously) create radial dimension strings with the Angular Dim, unfortunately at this time the Edit Witness Lines does NOT become available with that; kybd shortcuts do not allow it either.
  1. Dimension to Centerline
    By DaveP in forum Architecture and General Revit Questions
    Last Post: January 31st, 2013, 03:31 PM
  2. Inputting Angular Dimensions
    Last Post: November 26th, 2012, 05:02 PM
  3. Angular Dimensions acting like linear dimensions (up-down, left-right only)
    By Jobrowns in forum Architecture and General Revit Questions
    Last Post: December 6th, 2011, 08:50 PM
  4. temporary dimension (dimension snap) remains large and off screen when zooming in
    By birdnehru in forum Architecture and General Revit Questions
    Last Post: October 27th, 2011, 06:25 PM
  5. Revit Kid: Revit Tip - Dimension Options - Auto Dimension
    By The Revit Kid in forum Blog Feeds
    Last Post: October 8th, 2011, 11:16 AM
