Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By hroark
  • 1 Post By DaveP
Thread: Can't edit profile on wall
    December 15, 2010
    23
    07:43 AM
    Question Can't edit profile on wall
    (Using Revit 2010/Win7)
    For some reason, I cannot edit the profile on this particular wall in the project (the button is grayed out). It is a big wall with lots of profile edits already on it and tons of wall hosted components along it. The workset is editable and I've already tried 'make elements editable'. I do not want to 'reset profile' and start over with this wall because it is to close the deadline and there would be tons of cleanup to get it back to 'normal'. If I can't figure this out, I'm going to detail it using lines and regions, but of course I would rather not do that.
    The wall has 4 warnings on it that indicate 'highlighted walls overlap'. It is not 'attached' to anything. Edit profile seems to be the only thing that isn't working for this wall.
    What's going on here? Any ideas?
    Nantes, France
    1,380
    01:43 PM
    hi, maybe you should post your file here. we'll try and let you know. if the project is a huge one, make a group from this wall, link it to a new file and post it.
    30
    07:43 AM
    First thing to do is find out what those warning are about. Has the wall been copied onto itself? Are there walls embeded in the original wall?Warning cause all types of problems in projects and fixing them generally resolves other wierd issues.
    December 15, 2010
    23
    07:43 AM
    Duh! It turns out it was PINNED! Since it was a big wall and I was only seeing pieces of it, I never saw the pin until I was in a plan view, where it showed the entire wall. Sorry for the disturbance. Carry on.
    cganiere likes this.
    Gold Coast
    2,266
    09:43 PM
    Quote Originally Posted by hroark View Post
    your comments are appreciated, problems with solutions are better than problems without!
    March 20, 2017
    4
    06:43 AM
    I'm having this same problem if anyone has found another solution? wall is not pinned but is a curved CMU "basic wall". the edit profile button is grayed out. i'm needing to insert "cut outs" for fire proofing systems and plumbing going into the wall but for some reason on the curved walls i'm not able to? any ideas?
    Attached Thumbnails Attached Thumbnails Can't edit profile on wall-wall-edit.png
    Senior Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    786
    06:43 AM
    You can use Wall Opening tool (architecture tab -> opening panel). If you need a shape other than rectangular, use in-place void or face/wall based void family to cut the wall.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,537
    06:43 AM
    Quote Originally Posted by Chad00 View Post
    wall ... is a curved CMU "basic wall".
    That right there is your problem.
    You can't Edit Profile on curved Walls
    JeffH likes this.
    March 20, 2017
    4
    06:43 AM
    Thumbs up
    Yea, I just decided to go ahead and do cuts in the wall with a "wall opening" they can adjust in the field for different systems going in the wall. Thanks for the quick reply guys! (now I know)
    New Member aghilaskari's Avatar
    November 17, 2017
    1
    11:43 AM
    you cant edit profile on curved walls. but there is a way to do it. look at this video
    https://youtu.be/gcTUtjpcd74
  1. Wall Sweep: Shorten by grip edit, with doors
    Last Post: January 31st, 2018, 05:39 PM
  2. Edit Top of Curved Wall
    Last Post: July 16th, 2015, 06:29 PM
  3. edit Wall profile, or other workflow?
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: May 20th, 2011, 08:34 AM
  4. Wall profile
    By theshell07 in forum Architecture and General Revit Questions
    Last Post: May 10th, 2011, 07:33 PM
  5. Wall joining, cut profile? or..
    Last Post: May 6th, 2011, 04:02 PM
