Results 1 to 3 of 3
Thread: Beam Poking Through Roof Help
    Moderator Drew's Avatar
    December 9, 2010
    Perth, Western Australia
    689
    11:07 AM
    Well the title says it all really. See image
    I have a timber beam spanning from wall to wall and of course the roof is pitched, so the issue is the beam will pock through the roof sheeting (tiles)
    This is a structural beam family. How do I edit the profile of the beam to pitch with the roof so it will sit below and follow the roof line?
    Surely this can be done as building's will have this condition fairly regularly.
    Any help appreciated.
    Attached Thumbnails Attached Thumbnails Beam Poking Through Roof Help-beam-problem.jpg
    Moderator mark b's Avatar
    NSW Australia
    1,430
    01:07 PM
    Draw a reference plane where you want the cut then use cut geometry tool, select beam then Ref Plane.
    or
    Use cut by face. Home/Openings/Cut By Face
    I'd use the Ref Plane.
    December 9, 2010
    689
    11:07 AM
    Quote Originally Posted by mark b View Post
    or
    Just brilliant!!!!
    You are a life saver. If you are ever in Perth look me up. My shout.
  1. How to Roof Merge/Join to Lower Roof!!
    By crhdesign in forum Architecture and General Revit Questions
    Last Post: April 30th, 2011, 05:48 AM
  2. Post&beam
    By Mikle1982 in forum Architecture - Family Creation
    Last Post: April 18th, 2011, 05:44 AM
  3. Roof with different sloping - one roof or individual surfaces?
    By Clogboy in forum Architecture and General Revit Questions
    Last Post: April 9th, 2011, 12:47 PM
  4. Variable beam creation
    By lucis29 in forum Architecture and General Revit Questions
    Last Post: April 8th, 2011, 01:53 PM
  5. Beam and void
    By jbenoit44 in forum Structure - General Questions
    Last Post: March 19th, 2011, 03:58 PM
