Results 1 to 7 of 7
Thread: Can't grip edit ends of a wall sweep on a curved wall
    November 13, 2012
    Pacific Northwest USA
    5
    06:24 AM
    In Revit 2014 I'm trying to place a chair rail as a wall sweep on a curved wall. I can see the grips but am not able to select and move them as I expect to be able to. Am I missing something here? Sweeps placed on straight walls in the same model work fine...
    Thanks
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    09:24 AM
    Quote Originally Posted by NW_Reviteer View Post
    Thanks
    I am able to do it with no problems.... Are you used "tab" to make sure you are selecting the sweep ends??
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    08:24 AM
    I just did a quick test on a curved wall with a sweep on the inside radius and the outside radius. Both edit just fine with the grips.
    Can you post a screen shot of your wall?
    That's the second time in a row I was beaten to the punch.
    November 13, 2012
    5
    06:24 AM
    Can't grip edit ends of a wall sweep on a curved wall-sweep-grip.jpgCan't grip edit ends of a wall sweep on a curved wall-sweep-grip-wall.jpg Ok here is the wall, and a screen shot with cursor on the grip so I'm sure I'm getting the right selection. It's a very subtle curve, 520ft radius or so.
    November 13, 2012
    5
    06:24 AM
    OK, problem solved-ish. I tested in a new project and have the same issue in elevation and section. Apparently I can only edit in 3d view, not the interior elevation or section.... I created a duplicate default 3d view with a section box cropped to this floor so I can edit all the interior sweeps.
    Thanks for the quick responses.
    dzatto's Avatar
    December 9, 2010
    5,234
    08:24 AM
    yep. I always grip edit them in a 3D view. Glad you got it to work out.
    May 22, 2012
    Connecticut
    185
    09:24 AM
    Quote Originally Posted by dzatto View Post
    Haha... it's all about timing I guess!
    NW_Reviteer... I am glad you got it! I forgot to mention the 3D view...
  1. Wall Sweep: Shorten by grip edit, with doors
    Last Post: January 31st, 2018, 04:39 PM
  2. Edit Top of Curved Wall
    Last Post: July 16th, 2015, 06:29 PM
  3. Family Grip Ends
    By Shields08 in forum Architecture - Family Creation
    Last Post: August 2nd, 2013, 04:20 PM
  4. Edit profile of curved curtain wall ?!!!!!
    Last Post: April 22nd, 2012, 03:44 PM
  5. Curved wall opening / faced based family opening to curved wall
    By tjgreatrex in forum Architecture and General Revit Questions
    Last Post: November 11th, 2011, 12:48 PM
Tags for this Thread
