Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Transparent Glass not transparent in Section View
  1. #11
    Member Elisa's Avatar
    December 8, 2010
    Los Angeles, CA USA
    65
    01:49 PM
    Quote Originally Posted by Munkholm View Post
    True, you canīt make the "glass" sub-category transparent using VG - But you can turn if OFF (When itīs transparent, itīs not visible anyways )
    This doesn't work for me because I have no frame around my glass, so turning it off won't show the edges.Transparent Glass not transparent in Section View-glass.png The green is the structure, and the glass goes beyond it. We aren't showing how it's attached to the frame yet, but we do have details for it. So the symbolic lines in the family work to show the structure behind the glass in section.
  2. #12
    Moderator mark b's Avatar
    NSW Australia
    1,430
    06:49 AM
    when using show hidden line have you checked what your hidden line styles are set to in Object styles. In example i activate show hidden tool, I first select wall then structural framing -then window then structural framing. The line style is set in the "hidden component", hidden line style.
    Attached Thumbnails Attached Thumbnails Transparent Glass not transparent in Section View-untitled.jpg   Transparent Glass not transparent in Section View-1.png
  3. #13
    Kingdom of Denmark
    4,221
    10:49 PM
    Quote Originally Posted by Elisa View Post
    This doesn't work for me because I have no frame around my glass, so turning it off won't show the edges.Click image for larger version.
ID:	158 The green is the structure, and the glass goes beyond it. We aren't showing how it's attached to the frame yet, but we do have details for it. So the symbolic lines in the family work to show the structure behind the glass in section.
    Ahh... I figured that you where using the symbolic lines for the glass edges (In wich case my suggestion just might work)
  4. #14
    December 8, 2010
    Los Angeles, CA USA
    65
    01:49 PM
    Quote Originally Posted by mark b View Post
    I have it set to Hidden lines also, I'm already using that tool in other areas of the project, I'm not sure why it wouldn't work with this skylight. I didn't try to figure it out, I was spending too much time already. BUT now thinking about it, maybe because it's a family? What you show has 3 component/pieces, a wall a window and structural framing. What I have is a skylight family, so it's one piece. That's probably why it won't work. Thanks Mark!
  5. #15
    December 8, 2010
    Los Angeles, CA USA
    65
    01:49 PM
    Yes in that case it would work great! thank you for it!!
  1. Toposurface in section view
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: April 26th, 2011, 01:04 PM
  2. Not so transparent
    By Vanguard in forum Structure - General Questions
    Last Post: March 31st, 2011, 07:39 AM
  3. 3D View as Section?
    By WVReviter in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2011, 06:09 PM
  4. make window glazing transparent in 2011?
    By therrien in forum Rendering and Gallery
    Last Post: December 22nd, 2010, 04:53 AM
  5. 2D Transparent Glass
    By mark b in forum Architecture - Family Creation
    Last Post: December 15th, 2010, 07:15 PM
