Donate Now Goal amount for this year: 3000 USD, Received: 2460 USD (82%)
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree1Likes
Thread: Revit Views - How do i modify the Crop Region line style?
    December 3, 2012
    73
    07:01 AM
    Is this possible?
    June 29, 2011
    Denmark
    74
    09:01 AM
    Not that i know of. You can hide it, under print options.
    Callout line style, is changed in Object Styles -> Annotations -> Callout Boundery.
    Autodesk JeffH's Avatar
    December 13, 2010
    The Ivory Tower (Manchester NH)
    734
    03:01 AM
    On or off, that is the only user control over the crop region lines.
    Junior Member Arno's Avatar
    August 29, 2011
    Schoorl
    45
    09:01 AM
    You can't set the type, but you can overrule. Select the cropview, right click, override graphic in view, select an other pattern.
    You have to do this for evey view manualy
    December 3, 2012
    73
    07:01 AM
    I tried this in Revit 2014 and the overrides window only has the visible checkbox which i can use. All the rest is gone.
    Was this possible in an earlier version?
    Quote Originally Posted by Arno View Post
    Coeur d Alene, ID
    4,256
    12:01 AM
    Quote Originally Posted by basilmir View Post
    You can override sections and elevations only....won't work with floor plans...
    December 3, 2012
    73
    07:01 AM
    Just found that out myself. Even though they look the same it seems there's a difference between plan corp regions and section/elevation crop regions.
    I wonder why?
    June 3, 2014
    1
    07:01 AM
    I have a template that I created in an old version of Revit. There, I have plan views with crop region line style changed, and others no. Now I can't change when I create a new plan view, only if I duplicate the one with the line style changed.
    December 3, 2012
    73
    07:01 AM
    You are right, tried to do the exact same thing in Revit 2016, rather inconsistent if you ask me.
    January 3, 2016
    27
    08:01 AM
    I've come across this issue today. Looks like there's still no way to preset view crop style in Revit 2018.
    There's a revit idea on it here: https://forums.autodesk.com/t5/revit.../idi-p/6330724
  1. section mark still show up way beyond crop region and annotation crop
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: November 5th, 2017, 06:42 PM
  2. Crop Region rotation?
    Last Post: March 6th, 2012, 09:28 PM
  3. Do U Revit: Subtlety - Crop Region
    By Do U Revit in forum Blog Feeds
    Last Post: August 20th, 2011, 03:10 PM
  4. Crop Region in Elevations
    Last Post: May 27th, 2011, 02:46 PM
  5. Crop Region Overides
    By Alex Cunningham in forum Architecture and General Revit Questions
    Last Post: April 20th, 2011, 09:09 PM
