Results 1 to 6 of 6
Thread: Creating New Materials.........
    Member doni49's Avatar
    February 26, 2013
    Jefferson City, MO
    441
    03:57 AM
    I've written up a how-to sheet on creating a corrugated metal wall for other users in my office.
    Before I publish it here in the office, would someone be willing and able to give it a once over for me? I'd like a second opininion as to how easy/hard it is to follow as well whether or not I've missed anything that I should include.
    It would be greatly appreciated.
    TIA!
    Attached Files Attached Files
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,164
    04:57 AM
    Looks good overall.
    The one thing I'm not sure about is the use of tint rather than adjusting the material color. I just don't know enough about it to know if it's a good way to work or not.
    February 26, 2013
    Jefferson City, MO
    441
    03:57 AM
    Thanks. I thought tint WAS the way to change material color. Will dig deeper. Greatly appreciated!
    August 9, 2011
    Louisville, KY
    6,164
    04:57 AM
    There is a section for Material Color and a section for Tint.
    Attached Thumbnails Attached Thumbnails Creating New Materials.........-materials-editor.jpg
    February 26, 2013
    Jefferson City, MO
    441
    03:57 AM
    Thanks. I've since tried it and think I'm going to stick with tint -- unless something causes me to rethink that.
    I unchecked "Tint" and just to be sure, I didn't use a green color above. I set the "Generic" color to a shade of red.
    When I ok'd my way out to the drawing area, the green was gone. But it wasn't red either. It was the grayish white per the bmp file. It wasn't until I went back in and changed the "Image Fade" value to about 55 that the red appeared. But then the image didn't look very good anymore.
    August 9, 2011
    Louisville, KY
    6,164
    04:57 AM
    Quote Originally Posted by doni49 View Post
    the greyish white is because you have it set to use render appearance, which basically takes an average value of the texture and makes that the color. if you look at some of the OOTB materials they have a render material but for appearance it is set to an RGB value.
  1. Cannot get to materials
    By darryl in forum Architecture and General Revit Questions
    Last Post: February 28th, 2013, 11:41 PM
  2. Misaligned Materials
    By pixelforce in forum Architecture and General Revit Questions
    Last Post: January 22nd, 2013, 06:23 PM
  3. Showcase materials
    By narlee in forum Architecture and General Revit Questions
    Last Post: November 16th, 2012, 09:40 PM
  4. Mass materials
    By assem in forum Architecture and General Revit Questions
    Last Post: October 11th, 2011, 05:12 AM
  5. Materials
    Last Post: September 23rd, 2011, 12:22 PM
