Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Like Tree5Likes
Thread: Circular chain of references?!?!?!
  1. #11
    Senior Member Tim West's Avatar
    December 9, 2010
    Auckland, New Zealand
    609
    07:28 PM
    I user Scott's method, move with 'disjoin' checked by 0mm...
    The case that really gets me is when this error gets thrown upon selection.....
  2. #12
    October 18, 2017
    1
    09:28 AM
    Hi there, follow these steps:
    1. Check the name of the specific element that you are trying to copy, i.e. 300x300 rc column
    2. Navigate to the all the families that are currently loaded in your project in the project browser, this would be found under structural columns, delete it
    3. Re-copy the element, this should work.
  3. #13
    October 4, 2017
    1
    08:28 AM
    Who's reading this in 2018? haha
    I had the same problem with a wall (existing) and an added cladding on the facade (new) joined to make the new windows cut them through. Couldn't move or delete existing windows, or change phase for the involved elements. After unjoining the walls I managed to fix everything.
    I'm so glad I have find this topic thank you all
  1. Traduction n°6: plan de références et poignées bleues
    By jbenoit44 in forum Tutoriels, trucs et astuces en français
    Last Post: February 8th, 2011, 09:47 PM
