Results 1 to 9 of 9
Thread: Ramp spot elevation
    Member bangobeat's Avatar
    April 14, 2011
    263
    10:54 PM
    Ramp spot elevation
    How to show spot elevation dimension on the ramp? its kinda impossible now, but maybe somebody know it? i know its "bended" and its impossible to show, but middle point will be decreasing constantly, and i need to show it. How?
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    08:54 PM
    What kind of view are you in? I know that it's not possible to randomly place SE's on a continuous surface in Section or Elevation View. Only possible in Plan View.
    If you're in 2012, you might want to try to annotate in 3D. You can set this up using the Scope Box and Orient to View so that it looks like a section. Maybe then you can place these SE's (but I haven't tried it yet).
    April 14, 2011
    263
    10:54 PM
    Basement plan, and im using 2011..
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    08:54 PM
    Then it shouldn't be a problem. Can you post (part of) the project?
    April 14, 2011
    263
    10:54 PM
    I clicked on basement plan, save to new file.. dont know if its correctly
    Attached Files Attached Files
    Member Ben-May's Avatar
    December 8, 2010
    Melbourne,Oz
    305
    07:54 AM
    Looks like the ramp is above the cut plane?
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    08:54 PM
    Ok, the only thing I can think of is one of these solutions:
    1. Create a section across the axis you want to annotate. Go to the section view, draw a refplane aligned to the top of the ramp and annotate the refplane.
    2. Similar as above, but after creating the alligned refplane create two more refplanes on each point you want to annotate: one vertical and one horizontal (so you get a crosshair). name the horizontal refplane. go to the plan view and place the attached family on the intersection point of all three refplanes. Select as placement workplane the named horizontal plane. Now you can annotate this. Watch out though: this is simply a very small 2d circle created as a Generic Model. You might have to zoom in to see them.
    I'm guessing this problem has something to do with the curved surface of the ramp, so the only way to make it easier is to recreate the ramp.
    April 14, 2011
    263
    10:54 PM
    First of all my curved ramp is because i have a turn, and its geometrically correct that the ramp will be curved. Second, i cant align ref plane to the ramp because its curved ;] and fail is everywhere because its curved.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    08:54 PM
    I know, you'll have to do a manual alignment "on sight". All else fails I'm afraid...
  1. Spot Elevation in Drafting View
    Last Post: January 22nd, 2017, 11:07 PM
  2. Ramp problem
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: April 16th, 2011, 08:25 PM
  3. Spot Elevation Family
    By Elisa in forum Architecture - Family Creation
    Last Post: January 6th, 2011, 10:32 PM
  4. Spot Elevation Family - many applications
    By Alex Cunningham in forum Structure - Family Creation
    Last Post: December 14th, 2010, 02:30 PM
