Donate Now Goal amount for this year: 3000 USD, Received: 2460 USD (82%)
Results 1 to 5 of 5
Thread: Revit Room finish parameters
    May 30, 2013
    11
    08:02 AM
    Is there a way to enter room finish materials(Floors/walls/ceilings) in a room schedule or in a rooms parameters that will automatically apply that material to the rooms wall in the 3d model.(My building contains the one type of wall). Split face/paint tools create the material in the model but this information does not seem to link back to room schedules. I have also tried using room interior fill visibility and applying a fill pattern that is similar to the material yet this does not link to schedules either. Is there a simple way to link the material finishes of a wall to the rooms finish parameter?
    Member cerb0z's Avatar
    July 5, 2011
    Belarus, Minsk
    244
    10:02 AM
    No, at least until you actually model them.
    May 30, 2013
    11
    08:02 AM
    Quote Originally Posted by cerb0z View Post
    Thanks. If I create separate walls for each room is there a way for the rooms parameters to pick up the materials? Or is creating numerous wall types which only have different finishes and joining them bad practice?
    June 29, 2011
    Denmark
    74
    09:02 AM
    No not built in to Revit. There are various apps that does this. Autodesk's "Roombook" (i think it's a subscription app), is one that does takeoff on walls.
    July 5, 2011
    Belarus, Minsk
    244
    10:02 AM
    It is a most common practice but you'll need to create manual parametr for room name/number so walls.
    Quote Originally Posted by soender View Post
    Roombook is hardly useful (could be very slow on calculations or doesn't work at all, also needs a lot of time to set it up correctly) and afaik it still will not assign material to a wall from room finish schedule (not played with 2013 ver. much, but as fast check it had same bad perfomance as before).
    In other words, Revit is still pretty terrible for room finishes.
  1. Floor Finish Material to Room Tag
    By archizen in forum Architecture and General Revit Questions
    Last Post: May 28th, 2013, 01:14 PM
  2. Replies: 0
    Last Post: July 23rd, 2012, 01:16 AM
  3. Revit OpEd: Finish and Cancel Inequity
    Last Post: April 10th, 2012, 03:15 PM
  4. Specialty Equipment in Room but not Room Aware
    By GMcDowellJr in forum Architecture and General Revit Questions
    Last Post: January 26th, 2012, 08:36 AM
  5. Revit Kid: Revit Tip - Finish Editing a Design Option
    By The Revit Kid in forum Blog Feeds
    Last Post: September 20th, 2011, 09:30 PM
