Results 1 to 8 of 8
Thread: Graphic Overrides for Materials
    April 8, 2013
    8
    09:18 PM
    Does anybody know if there is a way to graphically override the cut pattern of a material for different views? We like to use a solid poche to show the core structure of our walls in plan but in section and details would prefer to not have the same poche at the core.
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,230
    08:18 PM
    Create a filter to put in your floor (or section and elevation) view template.
    Member Geert's Avatar
    February 8, 2011
    Les Vigneaux, Hautes Alpes, France
    127
    03:18 AM
    you can manage this setting the detail level of the view
    February 3, 2011
    London, Ontario
    397
    09:18 PM
    In vg overrides there is a setting to override wall layers as well. Might help with what you wan to achieve. It's near the bottom right corner if the vg overrides dialog.
    April 8, 2013
    8
    09:18 PM
    Using filters was able to accomplish what I was looking for. I was afraid that the filter override would change the fill pattern of the entire wall assembly and not just the core.
    March 20, 2012
    1
    03:18 AM
    Quote Originally Posted by jdotwhite View Post
    How did you do this??! Sounds great, but can't get there myself.
    Junior Member parleyburnett's Avatar
    April 22, 2013
    Bozeman, MT
    7
    05:18 PM
    Ya, not able to achieve only an override of the core boundary using filters. Any suggestions?
    9,185
    08:18 PM
    You can't, without parting and filtering parts. Model them separately or part them or get used to seeing them.
    Aaron Maller
    Director
    Parallax Team, Inc.
  1. Visability/Graphic Overrides on Linked Files - Underlay Option
    By MikeClothier in forum Architecture and General Revit Questions
    Last Post: March 12th, 2013, 01:17 PM
  2. Visability/Graphic Overrides on Linked Files - Underlay Option
    By MikeClothier in forum Structure - General Questions
    Last Post: June 21st, 2012, 02:06 AM
  3. 3D dwf with phases overrides
    By redmonki in forum Architecture and General Revit Questions
    Last Post: March 14th, 2012, 09:14 AM
  4. Saving V/G Overrides in every View?
    By tzframpton in forum Architecture and General Revit Questions
    Last Post: January 18th, 2012, 07:44 PM
  5. Overrides in Revit
    By djnelson75 in forum Architecture and General Revit Questions
    Last Post: May 20th, 2011, 04:57 PM
