Results 1 to 5 of 5
Thread: I broke my Revit =<
    Member Cyus's Avatar
    July 10, 2012
    London / MK
    488
    08:40 AM
    I broke my Revit =<
    !! This family is not loaded correctly
    So, I'm in the family editor, and I click on the parameters button. I get the error "!! This family is not loaded correctly, check..." in the Name: box, and now I can't do anything. Clicking any of the buttons doesn't work, I can't close the type dialog, nothing. So, I can't do anything now. =<
    Has anyone come across this problem before?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,556
    03:40 AM
    can you take a screenshot of the error?
    it's not one of these is it? example of how to NOT name a family type
    July 10, 2012
    London / MK
    488
    08:40 AM
    I've attached a screenshot. It's unusual because it simply won't let me do anything - clicking any of the buttons won't work. It's not unresponsive as in it's crashed though.
    It's not one of my families, but the file name isn't anything unusual.
    Attached Thumbnails Attached Thumbnails I broke my Revit =&lt;-reviterror.png
    8,481
    02:40 AM
    I think you are experiencing two seperate things:
    1. Something is fragged in your Revit UI. Did you recent install the windows updates that installed .net 4.5? If so, you need to be on 2013 WU2 or 2012 with the latest hotfix, or the UI goes nuts.
    2. Someone named the Family Type that, so make sure people use the Type Catalog, and not Load Into Project. I do that here as well.
    July 10, 2012
    London / MK
    488
    08:40 AM
    I probably botched the family import with the type catalog, that doesn't bother me as much. It's the UI issue that's more frustrating. I'm on 2013 WU2, and used it fine hours before, and since it's been fine also. I just wondered if there's a connection between this family issue and something that then locks the UI.
  1. I think I broke it...
    Last Post: October 19th, 2012, 06:30 PM
  2. 2012 broke my door families too
    By sdbrownaia in forum Architecture and General Revit Questions
    Last Post: July 14th, 2011, 07:09 PM
  3. Revit 2012 Broke My Door Families?
    By blusurfer in forum Architecture - Family Creation
    Last Post: April 21st, 2011, 11:42 PM
