Results 1 to 6 of 6
Thread: View Title Scale
    March 10, 2011
    Illinois
    13
    05:33 PM
    View Title Scale
    I recently had to set a floor plan to a non-standard scale in order to get it to fit on a sheet. I was able to get the title to say "Not to Scale" but I don't remember how. Now the plan has been revised and it will fit on the sheet at 1/16" scale but I can't get the title to list the scale correctly anymore, it still reads "Not to Scale". I am using the same view title on other views which list the scales so I don't think it is in the family. When I have the sheet active the "Not to Scale" is listed in the properties dialog but is greyed out. The project was started in 2010 but we recently upgraded to 2011. Any help is appreciated.
    Thanks,
    Kevin
    Member Chadwick17's Avatar
    Fort Collins, CO
    321
    04:33 PM
    Did you set it to Custom? Click the scale size for the view and set it back to 1/16"...
    March 10, 2011
    Illinois
    13
    05:33 PM
    I did set it to custom originally but changed it back to 1/16" and the title is still reading Not to Scale.
    Kingdom of Denmark
    4,230
    12:33 AM
    Sounds very strange... could you create a copy of the file, delete and purge everything besides the view and the sheet, and post the file here for review ?
    And welcome to the forum Nivek
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    05:33 PM
    See Alfredo's post (#3) in this thread. I bet this is what you did.
    March 10, 2011
    Illinois
    13
    05:33 PM
    That is it, thanks. I knew I had applied an override but couldn't remember where.
    Thanks again.
  1. Not To Scale
    Last Post: May 4th, 2012, 09:12 PM
  2. Revise View Title?
    Last Post: May 10th, 2011, 07:23 PM
  3. View Title with multiple Extension Lines?
    By RaiderArch in forum Architecture - Family Creation
    Last Post: March 30th, 2011, 04:13 PM
  4. Level (Elevation) in a View Title?
    By tidalwave1 in forum Architecture - Family Creation
    Last Post: March 29th, 2011, 06:17 PM
  5. Plan view DBViewType has invalid view direction parameter.
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2011, 02:21 PM
