Results 1 to 4 of 4
Thread: Grids, Scope boxes and Linked models
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,760
    07:16 AM
    One of my users is telling me:
    It seems that grids within a linked model won’t show if they are associated to a scope box.
    Anybody ever heard of this before?
    We're linking our Structural consultant's mole into our Arch and Grids were not showing up.
    They say they have traced it to the Scope box, but I've never seen that before.
    St. Louis, MO
    1,952
    07:16 AM
    See if they are also using Copy/Monitor for Grids.
    9,671
    07:16 AM
    There are a bunch of *gotchas* related to whats set in the Linked File and whether you can see something or not in your file (which has their file linked).
    If the grids are on a Workset set to not be visible by default, it USED to be the case that you had no way to see that workset ever. That may have changed when Workset visibility state changed, but i wouldnt know as i dont use them for that. Regardless, in their model i would check it out.
    If their scope box pushes the 3D extents of the grid beyond (or out of) your view range, it makes sense you wont be able to see it. It might show in their drawings if they are using 2D extents, which wont show in your drawings without By Linked View.
    Also remember if you have a workset unloaded in your model, and its named the same as one in theirs, theirs will hide too...
    St. Louis, MO
    1,952
    07:16 AM
    Can you open their model, see if Scope Boxes are applied, if so un-associate, then save and reload link as a test?
    We usually have a Arch. Shell Model and Interiors Model.
    Then Struct. and MEP models from consultants are linked into ours.
    We typically generate the Grid in our Shell, and then use Copy/Monitor to the other models.
    We also usually use Scope Boxes, and have not had the problem of not seeing the grids in linked models.
    We usually turn them off in View Templates, though.
  1. Managing Scope Boxes
    By Dandharma in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2015, 04:50 PM
  2. Scope Boxes--yes, no other in between???
    By cliff collins in forum Architecture and General Revit Questions
    Last Post: December 31st, 2012, 08:11 PM
  3. Elevation Depth & Scope Boxes
    Last Post: June 8th, 2012, 04:57 PM
  4. Revit OpEd: Scope Boxes
    Last Post: February 1st, 2012, 04:15 PM
  5. Revit Kid: Revit Tip - Using Scope Boxes
    By The Revit Kid in forum Blog Feeds
    Last Post: January 30th, 2012, 09:15 PM
