Results 1 to 7 of 7
Like Tree4Likes
  • 2 Post By edo
  • 2 Post By need4mospd
Thread: Revit 2014 and Revit 2012
    July 27, 2011
    Rotterdam
    20
    05:16 PM
    does anyone else have trouble with revit 2012 (A or S) after installing revit 2014? It seems to mess up my contextual tabs. Buttons that should be there have simply disappeared.
    edo
    edo is offline
    Junior Member edo's Avatar
    February 26, 2013
    Jakarta
    15
    10:16 PM
    I think Revit 2014 needs .Net Framework 4.5 as prerequisite. If you have it installed on your computer, that's the problem.
    Revit 2012 doesn't support .NET Framework 4.5.
    dzatto and colliert like this.
    Member need4mospd's Avatar
    March 2, 2011
    Houston
    480
    10:16 AM
    Quote Originally Posted by edo View Post
    Revit 2012 didn't support .NET 4.5. They put out a hotfix for it a couple weeks ago.
    Hotfix - Autodesk Revit 2012 - Ribbon behavior due to .Net 4.5 installation
    Tucson, AZ
    2
    08:16 AM
    Thanks, .NET 4.5 is installed with Revit 2014.
    The Hotifix helped fix my ribbon problem! Revit 2014 and Revit 2012-2014installdotnet.jpg
    December 21, 2010
    C.LONDON
    4,229
    04:16 PM
    Why do they not publicize this!?! I can't read every thread that gets posted here!
    Coeur d Alene, ID
    4,317
    08:16 AM
    Been working in 2013 90% of the time...so when I went to 2012 for something my panel headers are in a goofy order...such as add-ins show first instead of last. The hotfix didn't fix the order...is there a way to move panel header order?
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,558
    10:16 AM
    Revit 2013 requires Update 2 to fix the same (or at least a similar) issue.
    Here's the Revit Clinic post about it
    Revit 2013 \ 2012 Contextual Panels do not display or update - The Revit Clinic
  1. Replies: 0
    Last Post: April 1st, 2013, 05:45 AM
  2. Revit OpEd: Revit 2014 Properties Palette Tabs
    Last Post: March 28th, 2013, 03:15 PM
  3. Revit OpEd: Revit 2014 Selection Features
    Last Post: March 27th, 2013, 04:45 PM
  4. Replies: 0
    Last Post: March 26th, 2013, 11:15 PM
  5. Revit OpEd: Revit 2014 Features on Autodesk Site
    Last Post: March 26th, 2013, 03:45 AM
Tags for this Thread
