Results 1 to 3 of 3
Thread: Levels below showing
    Senior Member domsib's Avatar
    April 30, 2012
    586
    11:53 AM
    I am creating a ductwork model and I am working on level 2.
    There is no floor separting level 1 and level 2 so I can now see the ductwork from level 1 faint on my plan of level 2.
    How do I stop my level 2 plan from viewing things from level 1?
    I'm guessing its to do with View Range but I need help on what to select etc
    Thanks
    April 30, 2012
    586
    11:53 AM
    The second I posted this message i've just seen I had an underlay set to 'level 1' in my properties browswer. Turning this off worked.
    Member hypnox1's Avatar
    December 9, 2010
    The Mothership
    170
    06:53 AM
    Quote Originally Posted by domsib View Post
    Yep, expect to see underlay play havoc on all your levels as it is automatically set on view creation to the level below that has a floor plan associated to it.
  1. Levels
    Last Post: January 22nd, 2013, 04:36 PM
  2. Hiding Levels from Links, keep host levels - best practice?
    By tzframpton in forum Architecture and General Revit Questions
    Last Post: January 14th, 2013, 05:37 PM
  3. Levels (Plan Views) showing at wrong heights. Is this an easy fix?
    By honung in forum Architecture and General Revit Questions
    Last Post: January 4th, 2013, 06:23 PM
  4. Levels Box closed
    By senadra in forum Architecture and General Revit Questions
    Last Post: December 6th, 2012, 01:07 PM
  5. Floors with different levels
    By n8wex in forum MEP - General
    Last Post: August 16th, 2011, 07:00 PM
