Results 1 to 3 of 3
Thread: Removing family elements by parameters
    September 19, 2012
    26
    07:46 PM
    I attached a file to this post, it is a table with a set of legs that are able to be removed when loaded into a project. I need to be able to recreate this from scratch. Problem is I can not figure out how the original creator did it. The legs are controlled by two "Yes/No" instance parameters. But there is no other parameter working with the "Yes/No" parameter. Can someone please tell me how this was done?
    Attached Files Attached Files
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,201
    08:46 PM
    The yes/no is tied to the visibility of the legs.
    Attached Thumbnails Attached Thumbnails Removing family elements by parameters-visibility.jpg
    November 18, 2014
    India
    12
    06:16 AM
    It is Actually not a Yes/No parameter.
    The method they used was type visibility setting for your family.
    for further refer attached file.
    Thanks,
    Ramachandran G,
    BIM Engineer,
    Sanveo Inc.,
    mod edit: email removed
    It is good practice to not include your email in forum posts for your security.
    -cellophane
  1. parameters for family vs family type
    By jgu in forum Architecture and General Revit Questions
    Last Post: December 11th, 2012, 10:18 PM
  2. Removing Family Types
    By Drew in forum Architecture - Family Creation
    Last Post: November 14th, 2011, 10:11 PM
  3. Family Parameters
    By rboaz in forum Architecture - Family Creation
    Last Post: September 16th, 2011, 06:05 PM
  4. Family Type Parameters and "Export Family Types" functionality...
    By Twiceroadsfool in forum Architecture and General Revit Questions
    Last Post: September 7th, 2011, 07:05 AM
  5. Family content for timber frame elements
    By jorge in forum Architecture - Family Creation
    Last Post: July 19th, 2011, 06:37 PM
