Results 1 to 5 of 5
Thread: Wall Sweeps Missing Endpoints for adjusting
    December 20, 2010
    1,061
    09:39 AM
    It used to be when you added a wall sweep to the wall, it would automatically cut at openings and if you need to adjust it further there were little blue dots at each opening. These are there if the sweep is part of the wall assembly, but not if you use the wall sweep tool?
    10,277
    09:39 AM
    They should be there regardless...
    Orlando, FL, USA
    3,111
    10:39 AM
    When using the wall sweep tool, if "Cut by inserts" is active in the sweep's type properties, you do not get blue dots at the openings; if it is not active, you do.
    10,277
    09:39 AM
    I get blue dots at Wall Sweeps that are cut by inserts, all day long. Something has to be up with that...
    EDIT: Whoops, nevermind. No i dont, They are just cut by inserts even when cut by inserts isnt checked, LOL...
    10,277
    09:39 AM
    Wow, thats great though! Because when Cut by Inserts is checked, and the dots are gone, you dont get that crappy situation with the inability to shorten a sweep across an opening! I love it!
  1. scheduling wall sweeps by room
    By jameshs in forum Architecture and General Revit Questions
    Last Post: August 3rd, 2015, 09:43 AM
  2. Scale-adjusting Level/Grid Head Families
    Last Post: April 24th, 2011, 11:33 AM
  3. Profiles in Sweeps
    By dzatto in forum Tutorials, Tips & Tricks
    Last Post: March 17th, 2011, 08:53 PM
  4. Wall Sweeps , Parapets and how to tag them.
    By drafterjohn in forum Architecture and General Revit Questions
    Last Post: January 13th, 2011, 01:52 AM
  5. Dimension to Sweeps
    By jdpeakplatinum in forum Architecture and General Revit Questions
    Last Post: January 4th, 2011, 07:51 PM
