Results 1 to 4 of 4
Thread: Roof slab not showing up
    January 27, 2011
    KC,MO
    345
    07:21 PM
    I cannot get my roof assembly to show the proper layers in my 3/4"=1'-0", it only shows the outline. My detail level is set to fine, all other elements show up properly except for my roof. Any thoughts?
    Kingdom of Denmark
    4,230
    02:21 AM
    Hard to tell without having the file to mess with. But it could be related to a bug in 2011, as in this thread.
    The bug should be fixed in 2012, so you could try to update the file... or make a copy of the file, and delete+purge everything unrelated, and upload the file here.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    12:21 AM
    I can't see the picture (it gives me a " you're not logged in" error), but have a look at your Rafter Cut and Fascia Depth. I have seen this behaviour with sloped roofs and a Plumb Cut too.
    January 27, 2011
    KC,MO
    345
    07:21 PM
    Ok so I could only get the file to 6.3mb, so I had to upload it to dropbox.
    http://dl.dropbox.com/u/3060856/roof%20test.rvt
  1. Slab Edges!!!!
    By Alex Cunningham in forum Structure - General Questions
    Last Post: May 25th, 2011, 11:01 PM
  2. How to Roof Merge/Join to Lower Roof!!
    By crhdesign in forum Architecture and General Revit Questions
    Last Post: April 30th, 2011, 05:48 AM
  3. Creating floor slab
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: April 26th, 2011, 06:01 PM
  4. Waffle Slab
    By iitdesigner in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 02:13 PM
  5. Roof with different sloping - one roof or individual surfaces?
    By Clogboy in forum Architecture and General Revit Questions
    Last Post: April 9th, 2011, 12:47 PM
