Results 1 to 3 of 3
Thread: Architrave, Entablature Pediment
    April 8, 2011
    1
    09:36 AM
    What is the best approach to create classic architrave, entablature in a pediment? I also need to know how to create a cast stone profile that is at the head and jamb of a window.
    Orlando, FL, USA
    3,111
    10:36 AM
    Basically, anything that is not already an out of the box Revit family, must be modeled. There are 5 basic methods: extrusion, revolution, sweep, blend, and swept blend. You need to find the 2D profiles that make up these architectural elements, and create the solids, either as families or as in-place objects.
    Attached Thumbnails Attached Thumbnails Architrave, Entablature Pediment-entablature.jpg
    December 13, 2010
    Ambleside, Lake District, UK
    956
    03:36 PM
    If it's any help..
    Not for the proportion purist perhaps but I've used Haddonstone cad profiles to sweep moldings and other classical parts:
    http://www.haddonstone.com/CountrySelect.aspx
