Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Ventilated facade - best practice?
    Member cerb0z's Avatar
    July 5, 2011
    Belarus, Minsk
    245
    03:38 AM
    Curtain wall for panels, sure, but doesn't work good for so good aluminium frame, even multi walls approach. So i'm left with beams and wall reveals. Or maybe it'll be even easier to create bunch of line based families? In the end i need to have panels and frame elements layout with rough schedules (cost estimating for a client so he could choose supplier/contractor or even assemble it on their own) and details. Most likely there will be ton of a changes so i want it to be as flexible as possible.
    Ventilated facade - best practice?-test-project.jpgVentilated facade - best practice?-facciate-ventilate-001-big.jpg
    December 21, 2010
    C.LONDON
    4,394
    01:38 AM
    Quote Originally Posted by cerb0z View Post
    Why, what's the problem?
    July 5, 2011
    Belarus, Minsk
    245
    03:38 AM
    It likes to cut
    Hard to achieve something like that even with multi wall approach. Beams looks the best for that kind of work, only need find a way to make them follow curtain wall grid.. Ok it's possible to attach it's coarse lines to curtain wall grid (strangely only works at facade view, not in 3d).
    March 23, 2013
    3
    03:38 AM
    Hello my friend. Did you manage to find a solution. I am looking about this for a long time. My problems is that there are some restrictions regarding the maximum spacing between the vertical profiles. This is something difficult to achieve. In case you have something new please let me know.
    Thank you
    July 5, 2011
    Belarus, Minsk
    245
    03:38 AM
    Yes, used curtain wall for panels (ended up with like 5 types), beams for profiles and face-based family for brackets. Then you can attach beam centerline to curtain wall grid lines, lock dimensions for intermediate profiles. Worked pretty good but structural part of the job was done later in autocad by an engineer and it wasn't necessary to show frame in the arch model. Probably will post some pics later.
    March 23, 2013
    3
    03:38 AM
    That would be nice. Do you think you can share it with us?
    Regards
    July 5, 2011
    Belarus, Minsk
    245
    03:38 AM
    Quote Originally Posted by tiaccaelle View Post
    Regards
    Here it is, but everything is in russian so be careful As i said it contains only panels, they have parametric gap and "window panels" has instance parametrs for window depth, corner panels should be modified as a whole for scheduling though.
    Attached Files Attached Files
    Member Hirvio's Avatar
    March 8, 2011
    Zagreb, Croatia
    254
    02:38 AM
    I noticed your post earlier but didn't have time until now. Your facade looks nice. I did "window panels" in similar way as you did.
    But I was thinking of making separate curtain walls for horizontal and vertical frame instead of beams, e. g. vertical frame and rain screen panels in one curtain wall, horizontal frame and thermal insulation in another. I didn't have an opportunity to make it through a design development, but I think it would be more controllable than solitaire beams. What do you think?
    July 5, 2011
    Belarus, Minsk
    245
    03:38 AM
    That probably could work but mullions can act weird sometimes. When i first was discovering various strategies this method caused some problems (probably fixable). Definitely needs more testing because i think with some proper managing Revit could be a good tool for this type of jobs. Only need to find best solution as always.
    March 23, 2013
    3
    03:38 AM
    Thank you very much. You are very kind
  1. What is the best way to create this facade?
    By PHPWill in forum Architecture and General Revit Questions
    Last Post: November 15th, 2012, 04:35 PM
  2. Glass facade
    By Aussiejayne in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 7th, 2012, 12:44 PM
  3. timber facade question
    By joewallace in forum Architecture and General Revit Questions
    Last Post: December 6th, 2011, 12:18 PM
  4. Facade refurbishment project
    By Hirvio in forum Architecture and General Revit Questions
    Last Post: November 17th, 2011, 10:13 AM
  5. Unfold Facade
    By pfaudler in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 6th, 2011, 07:06 PM
