Results 1 to 5 of 5
Thread: Millwork drawings using Create Assembly
    October 30, 2012
    95
    12:34 PM
    Has anyone tried creating millwork drawings using the create assembly command in revit 2013? If you have, what problems have you come across (if any) Just wondering if we should change our millwork sheet creation methodology in our office.
    Any insight or a conversation on this topic would be appreciated.
    Thanks in advance
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    01:34 PM
    I haven't made shop drawings but I did create a set of drawings (layout dims for the casework guy) for some custom casework using the assemblies. Overall I think it's a great function. In 2013 you can place assembly views on any sheet which is a big step from 2012.
    edit: I would give a shot on a small job and see how it works for you.
    October 30, 2012
    95
    12:34 PM
    Chad,
    Did you come across and problems/disadvantage using the assemblies?
    I also noticed that you can create sheets inside the project browser assemblies folder (instead of the Sheets folders) any advantages/disadvantage to this when it comes to printing?
    Thanks for a quick reply!
    August 9, 2011
    Louisville, KY
    6,140
    01:34 PM
    For my purposes the create sheets wasn't great but I could see it being useful. I just created views and inserted as needed. It will create a ton of views - top, bottom, left, right, front back and about 15 sections. I only needed one or two of them and did it as much as an experiment as anything. I would do it again however.
    There are some limitations to assemblies though.
    RevitForum Blog: How to deal with Legends in Revit
    http://www.revitforum.org/tutorials-...nds-revit.html
    http://www.revitforum.org/architectu...-schedule.html
    http://www.revitforum.org/architectu...es-really.html
    http://www.revitforum.org/structure-...ng-layout.html
    http://www.revitforum.org/architectu...oups-when.html
    I'm sure there are others but there is plenty of reading there
    October 30, 2012
    95
    12:34 PM
    Thanks again!
  1. Assembly Codes/Uniformat
    By Aretap in forum Architecture and General Revit Questions
    Last Post: September 12th, 2018, 11:42 AM
  2. Assembly Views
    By DGoffron in forum Architecture and General Revit Questions
    Last Post: August 20th, 2012, 03:40 PM
  3. Multi-Window Assembly
    By cellophane in forum Architecture - Family Creation
    Last Post: March 6th, 2012, 02:03 PM
  4. Cad drawings to revit line drawings
    By Nathaniel101789 in forum Architecture and General Revit Questions
    Last Post: November 21st, 2011, 09:46 AM
  5. Assembly Codes
    By violet78 in forum Architecture - Family Creation
    Last Post: January 12th, 2011, 01:43 AM
