Results 1 to 9 of 9
Like Tree4Likes
  • 1 Post By Dave Jones
  • 1 Post By cellophane
  • 1 Post By Twiceroadsfool
  • 1 Post By Alex Cunningham
Thread: Import shared parameters into an existing shared parameters file
    Ree
    Ree is offline
    March 8, 2012
    US
    33
    03:07 AM
    Question Import shared parameters into an existing shared parameters file
    How do I import shared parameters from another discipline into my disciplnes shared parameters file?
    Regards
    Maria
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,491
    02:07 AM
    Quote Originally Posted by Ree View Post
    Regards
    Maria
    If you have a .rvt file that contains those shared parameters you can use Manage/Transfer Project Standards and transfer Project Parameters to your project that uses your shared parameter file. I believe that the imported SPs will be put in a group called Exported Parameters IIRC
    Ree
    Ree is offline
    March 8, 2012
    US
    33
    03:07 AM
    I am using my own set of shared parameters and have been given a text file of the other shared parameters I need to import. I do recall something about the Group Exported Parameters. Just the logistiocs of getting them in from the text file. Thanks
    Dave Jones's Avatar
    4,491
    02:07 AM
    There have been several threads about this issue here in RFO. You might start here then do a search for "shared parameters" and you'll come up with lots of hits
    Ree likes this.
    November 19, 2012
    5
    04:07 AM
    Revit Family Tools allows you to compare and merge shared parameter files (and it's free!)
    http://apps.exchange.autodesk.com/RVT/Detail/Index?id=appstore.exchange.autodesk.com%3aRevit-Family-Tools%3aen
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,143
    05:07 AM
    parameter jerk and whitefeet tools also have functions to copy SP's into families.
    Ree likes this.
    10,196
    04:07 AM
    If youre careful you can do it manually (in Notepad), as long as you modify the group numbers so they dont have any conflicts. Been doing mine that way since i started revit.
    Ree likes this.
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    02:07 AM
    I would like to emphasize you need to be careful doing this. If you are not good at staring a large bodies of text and finding the one character that's like the other use what Chad is talking about.
    Ree likes this.
    Ree
    Ree is offline
    March 8, 2012
    US
    33
    03:07 AM
    Thanks all. I took daves advice and found the links above very helpful. Going through revit was the easiest for me.
    Cheers all
  1. Shared Parameters File
    Last Post: December 4th, 2014, 09:55 PM
  2. Shared Parameters
    By cve60069 in forum Structure - Family Creation
    Last Post: June 11th, 2012, 01:50 PM
  3. Shared Parameters - need assistance
    Last Post: March 7th, 2012, 07:32 PM
  4. Shared Parameters
    By Ali Akbar in forum Structure - General Questions
    Last Post: April 26th, 2011, 08:19 AM
