Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Making sure all views and details are on sheets
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    10:29 AM
    This is a noob question if I've ever heard one, but here it goes:
    I'm at the end of a small project, so it's not a big problem now. But, on bigger projects, how can you be sure that all of your views, details, callout, section, etc. etc. make it on to a sheet? I can see issuing a set, then realizing there is a view missing.
    Any ideas? Or is it just a matter of checking and rechecking to make sure you have everything?
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    08:29 AM
    to the best of your ability manual checking is the best. Quality Checks is what we call them.
    This is also a way Revit can help in crunch time though. Browser Organization (see attached image) F1 has a lot of info on this.
    Attached Thumbnails Attached Thumbnails Making sure all views and details are on sheets-browser-organization-prop.jpg
    dzatto's Avatar
    December 9, 2010
    5,234
    10:29 AM
    got it. I'll check it out in the help files. Thanks.
    Revit Rendering Guru
    98
    08:29 AM
    You could create a View List Schedule and schedule the Family, View Name, Sheet, and Sheet Name fields. It won't show legends or schedules though.
    Attached Thumbnails Attached Thumbnails Making sure all views and details are on sheets-12-14-2010-9-24-55-am.png
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,489
    08:29 AM
    Quote Originally Posted by dzatto View Post
    View tab/Sheet Composition/View. If your view is in the list it's not on a sheet. I don't have Revit open right now but I think you need to be in a sheet to make this work.
    December 8, 2010
    Northern California
    3,567
    08:29 AM
    Quote Originally Posted by muttlieb View Post
    I like this I am going to add this into our template. Awesome for detailing! My soultion simply moves the view under the sheet in the browser.
    dzatto's Avatar
    December 9, 2010
    5,234
    10:29 AM
    Quote Originally Posted by Dave Jones View Post
    That's not accurate, for some reason. You do have to be in a sheet, so I opened my sheet with my schedules on it. Every schedule showed up in the list! It's obviously on a sheet, I'm looking right at it!
    10,175
    10:29 AM
    Theres a much easier way.
    You can create a Project browser sort called "Views not on sheets," and Filter by Sheet Number (it wont exist). Then the ONLY views that are in the top of the project browser, are the views NOT YET placed on sheets. Everything else is only accessible down in the SHEETS portion.
    If theres anything in the top, its not on a sheet.
    dzatto's Avatar
    December 9, 2010
    5,234
    10:29 AM
    Yep, just found it. Works great.
    Dave Jones's Avatar
    4,489
    08:29 AM
    well just shows to go ya that you get what you pay for. I use this method to check which view are not on sheet all the time. I never noticed that schedules didn't follow the rules. Probably because as soon as I create a schedule I put it on a sheet.
    Sorry for the bogus info. In the future I'm going to go with Aaron's suggestion also
  1. Views on multiple sheets
    Last Post: August 4th, 2014, 08:47 AM
  2. Scheduling door details
    Last Post: March 28th, 2011, 10:01 PM
  3. Rearranging views onto different sheets
    Last Post: February 11th, 2011, 02:40 PM
  4. Details with 2 views
    Last Post: February 9th, 2011, 12:30 AM
