Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By dzatto
  • 1 Post By jsnyder
Thread: Inputting Angular Dimensions
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,141
    05:06 PM
    I am inputting a set of existing plans and the angles for the foundation are all in Degrees, Minutes, Seconds (65D32'7") with no bearing directions (25'N65D32'7"E.) Is it possible to input layout geometry using that format? I've seen it in the site layout tools but I have no other bearings other than a few angles where the building turns.
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    04:06 PM
    Yep, just type it in like this:
    65 32 7 and it will rotate it 65D32'7"
    cellophane likes this.
    Member jsnyder's Avatar
    December 9, 2010
    AUGI Refugee
    347
    02:06 PM
    I think the easiest way to approach this would be to simply convert the DMS into decimal degrees. Depends on how many you have, I guess.
    Online Conversion - Decimal Degrees
    It's also fairly easy to do with the windows calculator.
    or what Dan said...
    August 9, 2011
    Louisville, KY
    6,141
    05:06 PM
    sweetness. thanks!
  1. Demolition Dimensions
    Last Post: May 21st, 2012, 03:52 PM
  2. Jogged Dimensions
    By lucis29 in forum Architecture and General Revit Questions
    Last Post: April 27th, 2012, 06:12 AM
  3. Angular Dimensions acting like linear dimensions (up-down, left-right only)
    By Jobrowns in forum Architecture and General Revit Questions
    Last Post: December 6th, 2011, 08:50 PM
  4. Dimensions like Tags
    By gaby424 in forum Tutorials, Tips & Tricks
    Last Post: August 16th, 2011, 07:44 PM
  5. Baseline Dimensions
    By dzatto in forum Tutorials, Tips & Tricks
    Last Post: August 5th, 2011, 11:49 AM
