Results 1 to 5 of 5
Thread: Staircase
    Northern Ireland
    5
    04:30 PM
    Staircase
    Currently finishing an assignment and require some help..
    Is it possible to create a small landing, by this a mean a level area for a break in the steps with the staircase tool.
    I hope ive explained my question ok, any help will be appreciated.
    December 13, 2010
    133
    11:30 AM
    I typically use a small floor for that. Or my slab has an 'tab' that is the level.
    Moderator mark b's Avatar
    NSW Australia
    1,430
    02:30 AM
    Select stairs enter edit sketch mode, select required risers drag or move required distance for landing then split GREEN boundry lines at landing.
    All done
    Attached Files Attached Files
    Northern Ireland
    5
    04:30 PM
    Yes that is the kind of staircase I am talking about, thank goodness someone understands me
    Thank you so much that is more help than I expected
    NSW Australia
    1,430
    02:30 AM
    My pleasure and good luck with assignment
  1. Staircase & Railing
    By theshell07 in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2011, 09:28 AM
