Results 1 to 4 of 4
Thread: What is the best way to create this facade?
    October 23, 2012
    3
    09:09 AM
    Can someone please point me in the right direction on how to create this facade element please?
    It is effectively an enormous frame with cladding panels to all sides.
    Ideally I need to be able to apply panels to this at some point, but really need help just getting the form to look like the image below (which was done quickly in sketchup).
    I can't seem to get the curved corners with a curved top, or create a continuous surface. Please can someone just advise me on the best way to get started?
    What is the best way to create this facade?-frame-north-aerial.jpgWhat is the best way to create this facade?-frame-curved-corner.jpgWhat is the best way to create this facade?-frame-plan.jpg
    Member renogreen's Avatar
    April 27, 2011
    Reno, Nv. USA
    335
    01:09 AM
    If it were me I would consider creating an in-place family. Easy to do using extrusions, sweeps, etc. I'm sure there are other ways, there always are, but that would be where I would start.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    08:09 AM
    I would probably create a mass, split the face to where the columns/beam should be, load it and then apply walls to face.
    October 23, 2012
    3
    09:09 AM
    Hi guys, thanks for the responses.
    I have tried using the split face option now and it is starting to get me somewhere, however when I get to these curved corners the split face option throws in a load of lines dividing the surface up when I make a mass from the 'opening' I've just drawn. It also loses the curve on plan. The flat parts work spot on though.
    Ideally I need to make it all one face so I can apply a grid to it and then add panelisation to it by pattern (I think this is the way to do it?!). Any ideas?
  1. Glass facade
    By Aussiejayne in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 7th, 2012, 12:44 PM
  2. timber facade question
    By joewallace in forum Architecture and General Revit Questions
    Last Post: December 6th, 2011, 12:18 PM
  3. Facade refurbishment project
    By Hirvio in forum Architecture and General Revit Questions
    Last Post: November 17th, 2011, 10:13 AM
  4. Unfold Facade
    By pfaudler in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 6th, 2011, 07:06 PM
  5. Walls on the floor, facade question
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: April 19th, 2011, 02:56 AM
