Results 1 to 6 of 6
Thread: Curtain Wall with base offset of 2' - help please.
    Junior Member digitalputty's Avatar
    September 26, 2012
    Denver, CO
    5
    12:45 PM
    I am taking a Revit 2013 class and one of the assignments has me create a curtain wall with a base offset of 2' "inside" a basic wall exterior - brick on wood stud. I've gone through the book we are using as well as other tutorials on the web and cannot figure out how to do it.
    Can someone please help me?
    Thanks!
    Larissa
    Coeur d Alene, ID
    4,738
    12:45 PM
    Do you have Properties Window open? If not, you should have it open at ALL TIMES...you would find out that your answer is right in front of you when you select the curtain wall.....(Take a look at the second parameter on the list )
    Good Luck with the tutorials and Welcome too!
    September 26, 2012
    Denver, CO
    5
    12:45 PM
    Thank you for the welcome!
    Yup! I have the properties window open (always). I've set the base offset at 2' but, I guess the real problem is that the curtain wall doesn't 'cut' through the brick wall. I've done 'cut' and that didn't help. :\
    September 26, 2012
    Denver, CO
    5
    12:45 PM
    OK! Figured it out ... I was trying to insert the WRONG type of curtain wall.
    Thanks for the help!
    Member jsnyder's Avatar
    December 9, 2010
    AUGI Refugee
    342
    12:45 PM
    If you edit the Type Properties of the curtain wall family, check the box that says "Automatically Embed". That causes the wall to be treated more like storefront in that you place it inside of another wall. Does that help?
    September 26, 2012
    Denver, CO
    5
    12:45 PM
    jsnyder
    - Thank you for your reply. I was trying to insert the wrong kind of wall. HA!
  1. █ Curtain Wall - Adjusting multi-storey wall from the bottom/ base... █
    By Spinalfarm in forum Architecture and General Revit Questions
    Last Post: November 8th, 2012, 07:41 PM
  2. Offset Curtain Wall Panel
    By DaveP in forum Tutorials, Tips & Tricks
    Last Post: June 8th, 2012, 08:15 PM
  3. Missing wall base
    Last Post: July 8th, 2011, 09:26 PM
  4. outlets in wall base
    By sca in forum Architecture and General Revit Questions
    Last Post: April 27th, 2011, 08:13 PM
  5. Curtain Wall pair of doors center offset?
    By Dave Jones in forum Architecture - Family Creation
    Last Post: February 21st, 2011, 04:02 PM
