Results 1 to 3 of 3
Thread: Doors disappearing inside curtain walls
    September 5, 2012
    2
    09:33 PM
    Hi There
    I have some regular doors placed in a curtain wall. They insert fine but when I try a edit the curtain grid the doors disappear inside the curtain panels. Picture attached should speak for itself...
    If I delete the doors and reinsert them it works fine but it's a load of hassle I could do without.
    Using Revit Architecture 2012.
    Thanks in advanceDoors disappearing inside curtain walls-curtain-wall-door-issue.jpg
    April 12, 2011
    Chicago, IL
    523
    04:33 PM
    How are you hosting the doors to the curtain wall? are you using regular walls as your panels? I didn't think doors could cut multiple panels. I'd try breaking the grids at the doors so they stay entirely on their own panel.
    September 5, 2012
    2
    09:33 PM
    Yeh I'm just using a basic wall type I created as the curtain panels. I'm trying to keep my curtain grids as simple as possible as there are some quite complex pattern elsewhere in my model that are giving me a headache. The doors cut multiple panels when you first drop them in, it's only after I tried moving the horizontal gridlines that cross the door opening that this happened.
    Thanks
  1. Joined walls and Doors- doors with different expected width
    By Hugo Tavares in forum Architecture and General Revit Questions
    Last Post: May 8th, 2012, 05:39 PM
  2. creating semi-open walls and doors
    By mno in forum Architecture and General Revit Questions
    Last Post: March 26th, 2012, 07:14 AM
  3. Windows and Doors on walls question.
    By wjnaim in forum Architecture and General Revit Questions
    Last Post: September 21st, 2011, 01:50 AM
  4. Room shading is blocking walls and doors
    By BrianHed in forum Architecture and General Revit Questions
    Last Post: August 3rd, 2011, 12:17 PM
  5. Custom/Standard Doors in Curtain Walls?
    By NLG in forum Architecture - Family Creation
    Last Post: April 12th, 2011, 06:39 PM
Tags for this Thread
