Results 1 to 2 of 2
Thread: Change Tag Geometry/Color with Change to Parameter
    December 21, 2010
    Phoenix, AZ
    2,644
    10:33 PM
    I'm pretty sure I know the answer to this but... is there a way to have the geometry/color of a tag change based on the value of a parameter it is tagging?
    We're doing plans to help describe where, for example, we have card readers, operators, etc. at doors. We've been doing this in Illustrator but now there's a desire to see how we could do them in Revit. The way things are currently done each function of the door gets a letter/color combination (yellow circle with a "C" for card reader, green square with a "D" for door operator, etc.).
    I know I can get the tag to read a parameter of the door to get the letter designation correct but getting the geometry/color of the tag to update based on the parameter is either trickier or impossible... I'm thinking the later.
    I would prefer not to have multiple tags for each geometry/color combination. It would be too easy to have the wrong tag displaying the wrong textual information.
    If I can't get the tag to update geometry/color based on the doors parameter I may be forced to do this with pieces of GA.
    Thoughts?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,190
    01:33 AM
    I think it could be done with nested tag shapes and some if/then statements.
    if typemark=C then family=card reader
    maybe...
  1. change instance parameter w/ "Edit" for multiple views/sheets
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2014, 08:56 AM
  2. Can I change the text color in a schedule?
    By Andres Franco in forum Architecture and General Revit Questions
    Last Post: August 29th, 2012, 09:55 PM
  3. Replies: 0
    Last Post: March 16th, 2012, 03:15 PM
  4. make arch width change along with width change ??!!
    By ahmed_hassan in forum Architecture - Family Creation
    Last Post: December 25th, 2011, 06:24 PM
  5. Change Topo Point Color
    By jsntg in forum Architecture and General Revit Questions
    Last Post: October 25th, 2011, 06:19 PM
