Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree1Likes
Thread: Editing Multiple Families
    April 12, 2011
    Durban, South Africa
    79
    11:12 AM
    Question Editing Multiple Families
    Hi All
    I am busy cleaning up my many families that I have collected over the last few years.
    I would like to open each family and do the following:
    1. Turn on Shaded for visual style for 3D Views: {3d}
    2. Orientate the {3d} view to front/top/right on the view cube
    3. Ensure that scale is set to 1:10 for {3d} view
    4. Ensure that the families Project Units are set to Millimeters
    5. Purge the file
    6. Compact the file
    7. Set thumbnail preview to 3D View: {3d}
    Is there any way to automate any of the above steps to speed up this process?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,164
    07:12 AM
    It would require either a macro or API but I'm interested in a solution as well.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,506
    04:12 AM
    I'd also be interested in a process to do this...It would be easy in Acad
    August 9, 2011
    Louisville, KY
    6,164
    07:12 AM
    Quote Originally Posted by Dave Jones View Post
    It would be nice if there was a way to make macros that didn't involve C# or .Net I never learned AutoLisp for the same reason.
    I downloaded a macro recorder for cleaning some files up but I had to sit there and watch it run every time I needed to do something.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    324
    01:12 PM
    This sounds like something that could be done by modifying the version upgrade script autodesk includes on the install.
    Start a new session of Revit, perform a sequence of those actions, close out Revit, find the journal file and compare that to the .txt file found at:
    C:\Program Files\Autodesk\Revit 2013\Program\en-US\Utilities\ContentBatchUtility
    Not sure since this isn't one of my own strengths, but if it is yours you might get it to work.
    April 12, 2011
    79
    11:12 AM
    Thanks for the responses.
    A macro recorder? Is that an external app? If so any suggestions on which one I should try?
    Yes I had also thought of something similar to the contentbatchutility!
    Dave Jones's Avatar
    4,506
    04:12 AM
    Quote Originally Posted by Craig Howie View Post
    a macro recorder generally just records keystrokes and then the resultant macro can be run in whatever program it is for. In this case there are no keystrokes to do what you want that I know of...
    August 9, 2011
    Louisville, KY
    6,164
    07:12 AM
    the window buttons can all be accessed with Alt+key combo (Alt+R, Alt+T etc) and you can tab through everything but it's a pain in the butt.
    Senior Member ahmed_hassan's Avatar
    April 25, 2011
    Egypt
    752
    11:12 AM
    i was about to be fired because of this API trying to learn it but getting out with nothing (not able to create one independent API, i can not grasp it although the sources i read !)
    it is needs strategy like plan steps ,returning commands, Enumeration ,!!!!!!!!!!
    Autodesk JeffH's Avatar
    December 13, 2010
    The Ivory Tower (Manchester NH)
    774
    07:12 AM
    You might be able to leverage a journal file to do somethign like this. There was a batch rendering tool that leveraged journal files and a bit of hacking to do batch renders in a project.
    buildz: Render Queue (ish) for Revit
    Not sure if it would work but it might be worth a try.
    I am pretty sure all of this could be accomplished with a custom API application. You might look into getting someone to write a custom app for you to do this.
  1. Editing the .ini
    Last Post: October 29th, 2013, 04:59 PM
  2. Very slow editing!!
    By aalen88 in forum Architecture and General Revit Questions
    Last Post: January 4th, 2012, 01:12 AM
  3. Replies: 0
    Last Post: November 10th, 2011, 01:45 AM
  4. Editing the Revit.ini...
    Last Post: November 3rd, 2011, 07:13 PM
  5. External Power Supply for Multiple LED Families
    By ericakoe in forum MEP - Family Creation
    Last Post: July 26th, 2011, 01:05 PM
