Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By spotless
Thread: void for curtain panels does not cut
    October 20, 2011
    UAE
    169
    01:50 AM
    Help!!!
    How can I create a curtain wall door or window family which will have a void to cut out some offset from neighboring panels? I made a curtain wall door family created ref planes with label for two sides and the top then created a void geometry and attached to ref planes. Now when I load it and apply to my walls it doesn't cut anything. I understand that there should be a sample wall (or panel in my case) in th family editor to be cut but for curtain based families I don't seem to find that. Anybody have done this before?
    designimpressions likes this.
    January 24, 2012
    23
    08:50 PM
    Any resolution to this?
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,490
    01:50 PM
    Quote Originally Posted by designimpressions View Post
    no answers probably because the original question isn't very clear. A window or door in a wall and a curtain wall door in a curtain wall are two completely different things. A curtain wall door does not need a void to be placed in a curtain wall, just replace a curtain panel with a curtain wall door. If you want a door in a wall, use a regular door, again, no void required. Same with a window. If that doesn't answer your question, please state what your issue is and how you're going about getting to the issue with what Revit content. The OP was obviously (to me) going to way to much trouble to accomplish something that is a snap in Revit.
  1. Sloped curtain system panels
    By hopfrog in forum Architecture and General Revit Questions
    Last Post: August 8th, 2012, 08:19 AM
  2. curtain wall panels
    By redmonki in forum Architecture and General Revit Questions
    Last Post: June 12th, 2012, 06:46 AM
  3. Curtain panels in room's embeded schedule
    By YarUnderoaker in forum Architecture and General Revit Questions
    Last Post: April 10th, 2012, 04:32 AM
  4. Existing Curtain Wall w/ New Panels
    By Chadwick17 in forum Architecture and General Revit Questions
    Last Post: March 14th, 2012, 09:03 PM
  5. Custom Curtain Panels
    By MikeMaloney in forum Architecture and General Revit Questions
    Last Post: January 9th, 2011, 02:09 PM
Tags for this Thread
