Results 1 to 2 of 2
Thread: Assemblies? Really?
    October 20, 2011
    UAE
    169
    12:46 PM
    Post Assemblies? Really?
    mdradvies I did go through your post about legend and assemblies.
    Well I thought maybe this is what I'm looking to achieve in Revit?
    Here is the thing.
    I have panel walls where I have to have elevations for each wall with its panels. In these elevation views I have to Tag each instance of these panels and these views must be named PW-01, PW-02 and so on. I have to make sure that I didn't miss any wall elevations. Then I have to have reference elevation marks in plan views with same PW-01 etc.
    And then I have to schedule my panels. (size and count wise). If I could make schedule for each wall with its panels that would also be nice.But in some cases I may have one wall which consists of one panel.
    In other words: Plan views with elevation marks > Elevation Views with according view names > Each panel instance tagged in each elevation view > Panel instances scheduled as per Size and count
    I want to understand if I could somehow use Assemblies in some correct way to achieve any optimized workflow in all above mentioned ?
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    07:46 AM
  1. Piping and assemblies
    By Tomcsie in forum MEP - General
    Last Post: August 27th, 2012, 08:59 AM
  2. When you will use Groups and when you will use assemblies?
    Last Post: August 12th, 2012, 09:55 AM
  3. Assemblies
    Last Post: October 4th, 2011, 06:47 PM
  4. Assemblies
    By Defiant1 in forum Structure - General Questions
    Last Post: August 24th, 2011, 08:51 AM
  5. Assemblies
    By xiqx in forum Structure - General Questions
    Last Post: August 6th, 2011, 12:38 PM
Tags for this Thread
