Page 10 of 10 FirstFirst ... 678910
Results 91 to 97 of 97
Thread: Preview of 2012 New Features
  1. #91
    Autodesk Scott D Davis's Avatar
    March 5, 2011
    Southern California
    657
    08:18 AM
    Quote Originally Posted by Andrew P View Post
    Another feature that sounds to good to be true is that, in theory, you can create a window schedule by using the assembly tool. I wonder if this is possible?
    yes and No, the Assembly tool (and resulting Assembly Views/Sheets) are a *subset" of the Drawing Set for the model. So once you create the assembly, and then the Assembly Views for the Window, the only sheet these views can go on is a sheet that is specific to that assembly. You'd have to have a separate assembly for esach window type in the project. If you made an assembly that contained all the window types, then the views would all show all of the window types as the are placed in the model.
  2. #92
    Member Wadeshuey's Avatar
    January 3, 2011
    Fontana CA USA
    128
    08:18 AM
    Scott... Thanks for the rundown last night at BUGIE.... cool stuff. Got my wheels turning!
  3. #93
    Moderator gaby424's Avatar
    December 11, 2010
    911
    05:18 PM
    http://www.youtube.com/user/Autodesk...27/YWkQPM68MRE
    It`s nice to see the shedule of parts. I think this can be a schedule enhancement too
    And the propertie palete of a part can be observed
  4. #94
    December 21, 2010
    C.LONDON
    4,392
    04:18 PM
    Quote Originally Posted by willsud View Post
    Does anyone know if the parts feature mentioned for walls and floors also applies to multi-layer roofs?
    For years I've had to duplicate roofs in order to make the slate layer oversail the timber eaves/structural layer and it would be nice if at last the roof layers could be unlocked to achieve this.
    Just a question really, but why did you have to wait for a new feature all those years when you could have used an in-place void sweep to cut the roof's eave profile however you wanted by sketch/loaded profile?
  5. #95
    December 13, 2010
    Ambleside, Lake District, UK
    956
    04:18 PM
    Hmm, I tried that in the early days but there is more to it than just creating the eaves as the verge slates need to overhang also and the quickest, cleanest method seemed just to create a slate roof with a structural roof under and where needed a plasterboard sloping ceiling under that. The separation of the elements was useful but tedious for rooflight penetrations.
    I'll have another look at that approach though, thanks.
  6. #96
    December 21, 2010
    C.LONDON
    4,392
    04:18 PM
    Oh I get your problem a bit clearer now, we've encountered the same when wanting to elaborate on our models. In the first, we'll make a roof-does-all sandwich construction (and often get away with it for the entirety of documentation as we use SIPS alot! ) but then we always model our ceilings seperate (to tag/colour override in our RCPs) and will generally end up with something like the below, using in-place model edits to define our edges "nicer" for elevations and "big scale" sections :
    but then encounter, as you say, the issue with penetrations. When we had to consider between-structure voids recently on a project (not using SIPS) and modelled roof, trusses & ceilings seperate, I was so glad to learn we'd not be having any skylights!
    So I guess, I'm not entirely sure how this new "peel away" tool is going to get around these kind of real-world working issues all that much? Or would Autodesk have us use shaft openings everywhere? Maybe it's something for another thread...
  7. #97
    December 13, 2010
    956
    04:18 PM
    That looks pretty good, thanks for showing it
    I never see anything so new - I tend to only get involved in roofs like this, for better or worse
  1. Revit 2012 - Autodesk 2012
    By jbenoit44 in forum Forum Français
    Last Post: May 11th, 2011, 07:07 PM
  2. 2012 Nice Features
    By mark b in forum Architecture and General Revit Questions
    Last Post: April 26th, 2011, 09:22 AM
  3. Revit 2012 Worksharing Features
    By safoulkes in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 10:08 PM
  4. Properties Dialog Thumbnail Preview missing
    By Ben-May in forum Architecture and General Revit Questions
    Last Post: February 22nd, 2011, 11:55 PM
  5. Familiy Browser 3.7- Reviewing the new Features...
    By Twiceroadsfool in forum Third party Add-Ins, API and R&D
    Last Post: February 8th, 2011, 11:11 PM
Tags for this Thread
