Results 1 to 4 of 4
Thread: Panel family Tag
    October 20, 2011
    UAE
    169
    04:07 PM
    Lightbulb Panel family Tag
    Hi guys,
    Do you know if it is possible to have a Wall Panel Tag to be automatically tagged on in elevation views?
    For example door and window tags come automatically, right?
    Can I edit my wall panel family and set a parameter which will have a specific tag on an elevation view of that given panel?
    Thanks
    Gold Coast
    2,631
    09:07 PM
    afaik when you place a door/window set to 'tag on placement' it only does so in your working view, are you placing your wall panel family in elevation? not sure if this feature is category limited, what category is your wall panel family? (if it's a family it can't be system type wall category)
    October 20, 2011
    UAE
    169
    04:07 PM
    Yes, it didin't work, it is'nt not a system family it is just a custom curtain panel, but what if I edit the family and add a parametric annotation indicating it's Height and Width? Do you think it will work?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,190
    07:07 AM
    You will need to load a tag for curtain wall panels but the tag-all will work in elevation just as well as in plan.
  1. Nested door in curtain wall panel, family
    By Alfienoakes in forum Architecture - Family Creation
    Last Post: July 20th, 2012, 04:24 PM
  2. Revit MEP Panel
    By MeSoNaM in forum MEP - General
    Last Post: November 8th, 2011, 09:06 AM
  3. Replies: 5
    Last Post: October 8th, 2011, 05:11 PM
  4. Where did the group panel go?
    By Alfredo Medina in forum Architecture and General Revit Questions
    Last Post: March 16th, 2011, 07:17 PM
  5. Panel walls - Again
    Last Post: February 4th, 2011, 01:34 PM
Tags for this Thread
