Results 1 to 7 of 7
Thread: Sloping roof structure and tapered insulation
    August 31, 2012
    3
    09:44 AM
    Is it possible to slope the roof structure to follow the two scenarios in the attached?
    Also, is there a way to create tapered insulation as shown in the attached scenario?
    Thanks!!
    Attached Files Attached Files
    9,878
    10:44 AM
    Several ways to do it, just not with one roof. Either use one roof for the sloped structure and another for the tapered insulation (Shape edited, variable thickness), with some careful Join Geo... Or use the roof with the sloped structure, and a family for the tapered insulation. Both methods work fine.
    August 31, 2012
    3
    09:44 AM
    I have tried to use the shape edit, with variable thickness, but this seems to involve some trial and error. Is there a step by step process that I could follow?
    How would you use a family for tapered insulation?
    9,878
    10:44 AM
    I personally wouldnt, but other people do. I use a roof for it. It does take some getting used to, but unfortunately i dont have instructions typed out.
    Keep trying!
    August 31, 2012
    3
    09:44 AM
    Basically, do you draw the profile of the tapered insulation in plan view and adjust the elevations of the points with the shape editing tool?
    9,878
    10:44 AM
    Quote Originally Posted by max2527 View Post
    Yeppers! If your end points are sketched on a line of the roof (they should be... ridges and valleys) it will snap in 3d while you raise and lwoer the points, too.
    Senior Member Tim West's Avatar
    December 9, 2010
    Auckland, New Zealand
    589
    04:44 AM
    ....with some careful Join Geo... Or use the roof with the sloped structure, and a family for the tapered insulation. Both methods work fine.
    With the Join Geometry tool (except with hardwired conditions) the first-clicked object will cut the second-clicked object.
    You can use the align tool on points/edges of a shape edited floor.
    Have you tried 'Pick Supports'? If you have generated the underlying structure, this is a quick way to generate your floor geometry...
    Attached Thumbnails Attached Thumbnails Sloping roof structure and tapered insulation-roof-support-view.png   Sloping roof structure and tapered insulation-roof-support.png
  1. Flat roof with tapered insulation
    By need4mospd in forum Architecture and General Revit Questions
    Last Post: June 20th, 2014, 02:02 PM
  2. Roof Modeling - Tapered Trusses
    By LKeyser in forum Architecture and General Revit Questions
    Last Post: July 9th, 2012, 05:50 PM
  3. Building Coder: Pipe Insulation and Insulation Material
    Last Post: May 24th, 2012, 09:15 AM
  4. Revit OpEd: Five Minutes of Roof Sloping
    Last Post: March 28th, 2012, 03:15 PM
  5. Roof with different sloping - one roof or individual surfaces?
    By Clogboy in forum Architecture and General Revit Questions
    Last Post: April 9th, 2011, 12:47 PM
