Results 1 to 6 of 6
Thread: Copy shared paramters in bulk
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,555
    02:41 PM
    I'm pretty sure at one point I saw an add-in for this but can't remember where. I'm creating doors & windows and would like to add a bunch of SP's to my famlies in one shot, rather than having to create a bunch of parameters one at a time. Is there something that can do this (2013)?
    Moderator mark b's Avatar
    NSW Australia
    1,426
    06:41 AM
    If you have Extensions for Revit loaded then there is an addin in there to do exactly that. Extensions/Tools/Shared-Project Parameters
    Attached Thumbnails Attached Thumbnails Copy shared paramters in bulk-sp.jpg
    December 21, 2010
    C.LONDON
    3,922
    07:41 PM
    If you don't have extensions, there's always Parameter Jerk
    NSW Australia
    1,426
    06:41 AM
    Yep, but sadly no 2013 version yet.
    December 21, 2010
    C.LONDON
    3,922
    07:41 PM
    Quote Originally Posted by mark b View Post
    I understood there were complications in template authoring in 2013 (but I might have read that wrong) so there's always doing it in 2012 and upgrading.
    June 25, 2012
    2
    05:41 AM
    Hi, this may be overkill for what you want but "ARUtils - Head of the Family" handles this sort of thing. It also does things like swapping parameters, changing values of parameters, deleting unused materials, renaming nested families, establish standardised preview icons, check against ANZRS standards, etc.
    Not a cheap option, but if you have thousands of families that you want to validate and correct its a real time saver. Admittedly as the developer I'm biased.
  1. text font or parameters bulk conversion
    By biff in forum Architecture and General Revit Questions
    Last Post: December 6th, 2011, 11:17 PM
  2. Copy/Monitor Help
    By Elisa in forum Architecture and General Revit Questions
    Last Post: November 16th, 2011, 11:32 PM
  3. Replies: 0
    Last Post: August 11th, 2011, 07:20 PM
  4. Revit OpEd: Shared Coordinates and Copy Monitor
    Last Post: July 22nd, 2011, 10:11 PM
  5. copy - monitor
    By jbenoit44 in forum Structure - General Questions
    Last Post: December 20th, 2010, 06:48 AM
