Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Like Tree20Likes
Thread: View Title with Graphic Scale Bar
  1. #21
    July 14, 2015
    1
    01:07 AM
    So No one ever came up with an automated solution to this? and mainly question the need for it as far as I see?
    Well unfortunately it is required by certain jurisdictions (Chicago in my Firm's case)
    http://www.cityofchicago.org/dam/cit...onEPermits.pdf
    If you scroll down to page 7 of the Applications guidelines of that link, you will see if more than one scale is used on the same sheet (happens PLENTY) then you are required to provide a graphic scale with each drawing.
    So I'm continuing on the crusade to find a way, because this is PAINFUL, 40+ viewtitles is awful.
  2. #22
    December 21, 2010
    Phoenix, AZ
    2,599
    06:07 PM
    Dynamo... maybe... if you're a good coder.
  3. #23
    March 16, 2012
    48
    08:07 PM
    DDrecoll,
    There is an app that can help you out. It is called Parametric Graphic Scale from Egan BIM Resources.
    The app works with Imperial or Metric scales and is designed to comply with NCS.
    The app is available on the Autodesk Apps Exchange, or you can check it out here.
    Ning Zhou likes this.
  4. #24
    November 2, 2011
    Slaithwaite ("Sla wit"), W Yorks, UK
    245
    02:07 AM
    We don't apply scale bars to individual title views here, but we have two sets of scale bars that are in the sheet title family, controlled by a toggle. One set is for GA scales, and the other for detail scales.
    In my previous practice, we did use view specific scale bars, which I implemented when I realised that contractors on site were photo-copying individual details from the drawing sheet to give out to the teams on site. The scale bar is a useful sense check to indicate if the copy is an accurate scale or not. We found a family on-line which did the job superbly and the fact that the scale has to be set manually for these things is an inconvenience worth suffering. I can think of many reasons why scale bars are useful and should not be dismissed as old-fashioned. Just so long as those responsible for pricing and construction follow the well-understood rule of never scaling off drawings!
    In any case, in the UK, it is a requirement for planning drawings at least to have scale bars. Presumably, because it is common practice for randomly scaled-down copies of submitted drawings to be distributed to individuals involved in the planning decision...
    View Title with Graphic Scale Bar-fdg_scalebars_detail.jpgView Title with Graphic Scale Bar-fdg_scalebars_ga.jpg
  5. #25
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    08:07 PM
    Kinda seems like a contradiction in terms there.
    • "Do not scale from this drawing."
    • "Here's a handy scale you can use."
    Steve_Stafford and JeffH like this.
  6. #26
    February 5, 2012
    47
    01:07 AM
    Quote Originally Posted by PeterJEgan View Post
    DDrecoll,
    Is this something you have a financial stake in? If so, can you please be upfront about that in your recommendation?
    thanks
  7. #27
    November 2, 2011
    245
    02:07 AM
    ...but you missed 'To be used only as guidance'.
    Scale bars are mandatory in the UK for certain classes of drawings, so we just use them for all.
  8. #28
    Junior Member scourdx's Avatar
    July 4, 2013
    42
    06:07 PM
    I usually add them because of our clients have Letter/Tabloid size multipurpose printer. Most often they would print to scale. Here is all-in-one scalebar I've created so it is display for Imperial, Metric and Engineering scale.
  1. Confused about View Scale and Detail Level
    By terran in forum Architecture and General Revit Questions
    Last Post: March 3rd, 2012, 06:06 PM
  2. How to view Section view lines on a plan view bigger than 1:100 scale
    By eks_al in forum Architecture and General Revit Questions
    Last Post: January 17th, 2012, 11:41 PM
  3. GA + DC + view scale
    By Ning Zhou in forum MEP - General
    Last Post: August 15th, 2011, 05:50 PM
  4. Display scale on a view title of a 3D view?
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: July 12th, 2011, 08:46 PM
  5. View Title Scale
    By Nivek in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 02:15 PM
Tags for this Thread
