Results 1 to 3 of 3
Thread: Door tags and Room numbers
    July 13, 2011
    Cleveland, Ohio
    11
    05:47 PM
    Is there any way I am able to get a door tag to read a room number. I tried to think of ways for a little while but kept running into problems when it came to reporting to a door schedule. I've heard they exist possible as a tool/add-in for revit. Is this correct?
    Thanks
    December 20, 2010
    1,071
    05:47 PM
    Put the Room name and Number in a schedule right next to the door number and then update the door number.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,186
    05:47 PM
    There is an addon that will do something similar but the name escapes me at the moment. Scott's method is easy and just as fast.
  1. Invisible room tags (Revit MEP)
    By Justin8304 in forum MEP - General
    Last Post: October 25th, 2016, 11:06 PM
  2. Door properties "From Room: Number" does not change when door flipped
    By hclbaumbach in forum Architecture and General Revit Questions
    Last Post: September 19th, 2012, 07:48 PM
  3. Door Tags/Schedules
    By debshaupt in forum Architecture and General Revit Questions
    Last Post: May 4th, 2012, 05:59 PM
  4. Default Position of Door Tags (or any tags for that matter):
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: December 23rd, 2011, 08:45 PM
  5. Phasing and Room Numbers
    By Patrick in forum Architecture and General Revit Questions
    Last Post: August 5th, 2011, 03:19 AM
