Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Like Tree2Likes
Thread: Constraints & array
  1. #11
    August 12, 2011
    80
    11:43 PM
    Quote Originally Posted by mark b View Post
    Here is an old tutorial from Mr Spot (old Augi days), I have had hanging around for years, for a louvre nested array with angle parameter for louvre. Worth doing just for the experience.
    Thank marc b. I am going to learn about this...
  2. #12
    December 27, 2014
    10
    03:43 AM
    Quote Originally Posted by RonPalmaAEC View Post
    I was able to accomplish this by the following:
    1. Create a Reference Line the initial desired length.
    2. Add a Length Dimension to each end of the Ref Line.
    3. Create Sweep/Swept Blend by using the Ref Line as the Path.
    4. Create the Profile shape/shapes
    5. Array the Sweep/Swept Blend, the Reference Line, and the Length Dimension.
    Ron Palma
    Ideate Inc.
    I get this message when I attempt to array an item which has been modelled around a reference line....
    "References to elements outside the group were removed from a grouped curve element."
    This means that it loses its reference to the line when arrayed.
    I think Revit is slowly draining my will to live
  3. #13
    August 19, 2011
    New Hampshire
    496
    06:43 PM
    Quote Originally Posted by seychellian View Post
    You followed the wrong method. Follow the nested family element for your array method listed in this thread.
  1. Array nested voids in a family
    By dzatto in forum Architecture - Family Creation
    Last Post: May 25th, 2012, 02:10 AM
  2. Interiors & equipment loading | Creating RDS & RLE packages
    Last Post: May 6th, 2011, 08:49 AM
  3. Design options and constraints
    By jbenoit44 in forum Architecture and General Revit Questions
    Last Post: April 12th, 2011, 11:33 AM
  4. Controlling width and length of array in line based families
    By tweg in forum Architecture - Family Creation
    Last Post: April 5th, 2011, 01:57 PM
  5. Array in a family
    By kingjosiah in forum Architecture - Family Creation
    Last Post: March 22nd, 2011, 09:50 PM
Tags for this Thread
